Electronics galvanic button
Discussion in 'Modding' started by Bruno_me, 31 May 2003.
  1. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    this may very well be a stupid question, but is there a way to use galvanic electricity that goes through you body to act like a button...
    like tuoch a peice of metal and a CD-rom opens... I've seen it on a Stereo once, and think it would be cool for a computer.
  2. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    You mean touch sensor's ??
    A piece of metal and when u touch it , it acts as a momentary switch ??
    Get the QT110 chips from Farnell, code is 362-5825
    Its a touch sensor IC...
    Good luck
  3. Bruno_me
    30 Mar 2003
    yeah, that's the thing
    EDIT: but I need something in the US
  4. DeX
    DeX Mube Codder
    22 Jul 2002
    I asked Zap how one of our light switches downstairs works. The switch is kind of like a really sensitive touch sensor but I know that it doesn't work by touch. It looks just like a rectangle peice of metal which when touched by either your hand or an earthed conductor (ie not a loaf of bread - that won't work) it'll either turn the lights on or off, or dim/brighten them depending on how lon you hold the switch. I can't remember what Zap said as I didn't really understand it but I didn't hear him mention anything about galvanic electricity. I'll try to look for the thread.
    Here is the thread: link
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Hmm, farnell.co.uk doesn't seem to come up with any matches for that order code.
  6. Bruno_me
    30 Mar 2003
    yeah, same for me
  7. Lovah
    10 Jul 2002
    Well..
    I just went to farnell.com .. then clicked my own little flag (belgium) ... They had them there...
    SO I assume u can get it in the UK aswell ...
    Enter the QT110, maybe ?
    I don't really know exactly how it works .. but its something with earthing the little metal plate..
    u actually dont really have to touch the metal.. if they are behind a thin piece of plexi .. it will work aswell (lets say 1mm for example)
    cant explain how.. but it does -miracle-
    (we need a miracle smilie... dont know how that would look like though)
    I cant say I have tested it myself...
    but I'm positieve it will work without the plexi (just by the touch)
    EDIT: http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=TS1
  8. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    It the same code, but without the hypen in betweeen.
  9. Bruno_me
    30 Mar 2003
    the only problem is I need it in the US
    and I lloked at the company who makes them, and apperintly, the toggle on and off, but not momentary...
    and out of curiosity, is there a way to do it without chips, but with something else???
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Most high-gain transistors will give you a crude switch if you touch the base lead, it's like the noise u get when u touch an amplifier input. Set it to drive a switch instead of a speaker. ;)
  11. Bruno_me
    30 Mar 2003
    thanks, everybody, all you ranswers were helpfull. but I'm probably going to go with the transistor though
  12. Lovah
    10 Jul 2002
    Yeah there is
    http://www.aaroncake.net/circuits/touch.htm
    It's not the same thing .. here u will need 2 little plate's .. and when u touch bouth of them , the switch is activated... (momentary (depends on how big the capacitor is)
    Good luck
  13. SteveyG
    23 Nov 2002
    That's very strange. It finds the product now... :confused:
    That circuit Lovah posted the link to works, as I have tried a similar configuration myself.:thumb:
  14. Renko
    Renko What's a Dremel?
    19 Feb 2002
    farnell online search sucks.
    We get told in uni to look in the catalogue if we're looking for specific stuff such as chips.
  15. Lovah
    10 Jul 2002
  16. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    those touch sensor ICs work on a change of capacitance dont they?
  17. fatal_error
    fatal_error What's a Dremel?
    3 Jan 2003
    yea they work on some kind of capacitance circuit involving you and the ground. somin to do with dear old kirchhoff and his merry laws
  18. bsodmike
    bsodmike Banned
    11 Oct 2002
    362-5825 is the Farnel code for the QT110-D (DIP) and this is the Active Low version.
    Click here for more information on these chips.
    How Kirchoffs Current Law Comes Into Play - taken from datasheet
    Like all capacitance sensors, the QT110 relies on Kirchoff's
    Current Law (Figure 1-5) to detect the change in capacitance
    of the electrode. This law as applied to capacitive sensing
    requires that the sensor's field current must complete a loop,
    returning back to its source in order for capacitance to be
    sensed. Although most designers relate to Kirchoff's law with
    regard to hardwired circuits, it applies equally to capacitive
    field flows. By implication it requires that the signal ground
    and the target object must both be coupled together in some
    manner for a capacitive sensor to operate properly. Note that
    there is no need to provide actual hardwired ground
    connections; capacitive coupling to ground (Cx1) is always
    sufficient, even if the coupling might seem very tenuous.
    For example, powering the sensor via an isolated transformer
    will provide ample ground coupling, since there is
    capacitance between the windings and/or the transformer
    core, and from the power wiring itself directly to 'local earth'.
    Even when battery powered, just the physical size of the
    PCB and the object into which the electronics is embedded
    will generally be enough to couple a few picofarads back to
    local earth.
  19. SteveyG
    23 Nov 2002
    Whoa this thread is 6 moths old :eeek: Why dig it up? There's already another newer thread about these.
  20. cpemma
    cpemma Ecky thump
    27 Nov 2001
    One of the penalties un-documented features of asking ppl to :search:
    :D
