(please move if this is in wrong thread, was not sure) Guys Looking at game capture cards for my PC, i have tried the software route but i always get FPS issues even though i use a separate HDD Has anyone got any recommendations for a capture card, I was looking at the Elgato HD 60 Cheers
Basically i5 3450 HD 7950 8GB RAM 3x 500gb HDD 1x 1TB SSHD Does this matter for a capture card? Thanks Parge
No, I was just thinking, have you tried using AMDs inbuilt game recording software? Your card supports VCE so it will use the hardware encoding on your GPU - meaning almost no performance degradation or skipped frames.
Were you using QuickSync or just regular CPU encoding? If it's the latter then have a look into quicksync. Requires some set up of the IGP IIRC, but it helped a friend stream Elite Dangerous so I could watch them play.
