Windows Game Xp
Discussion in 'Software' started by xckid082488, 18 Sep 2004.
Thread Status:
Not open for further replies.
  1. xckid082488
    xckid082488 Banned
    18 Sep 2004
    Its an incredible tool for avid gamers that optimizes Windows XP for gaming.
    See it here, http://www.techwarelabs.com/downloads/?action=file&id=172
    Well, it sounded really cool so I set a system recovery point just incase. So I downloaded it, unzipped it, and ran it. It restarted in half the time it usually does and farcry ran much smoother than it usually does. Everything in windows loaded/ran faster than ever then I discovered something. I couldn't connect to the internet through my wireless router. :waah: So I was forced to restore to the point I had just made. I'm so pissed, windows was running so fast. I highly recommend you try this if you dont have a wireless router, and if your really tech savey try to fix it if you use a wireless router and if you do get back to me :thumb:
  2. a9on87
    a9on87 ...
    2 Nov 2003
    I believe you have already posted this in hardware & oc!
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    :sigh:
  4. xckid082488
    xckid082488 Banned
    18 Sep 2004
    I am a F***ing genius, Game Xp increased my counterstrike source stress test from 85fps to 103fps, and I also fixed my wireless router problems and you can contact me and I'll tell how to do it because it's extremely easy. :thumb:
  5. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Why are u so obessed with telling everyone about this software? Do u own it and trying to advertise it?
    And does it work? I'm about to find out - restarting computer...
  6. TekMonkey
    6 Dec 2002
    I'm the real genius, it says so below my name.
    How are your router problems relevant and why would I want to know how you fixed them? :thumb:
  7. MrWillyWonka
    25 Jul 2004
    The only thing I noticed different on my computer was that the start menu came up faster - quite simply the visual effects were disabled. I didnt notice any other difference, so i went back to windows defaults.
  8. dom_
    dom_ --->
    4 Jan 2004
    its a service killer no?
    and it looks like it killed all the ethernet stuff and internet, to free resources thats all....
    i dunno though havnt used it.
    you can do this manually you know? and with differetn profiles so boot up into game for games, etc etc
  9. MrWillyWonka
    25 Jul 2004
    Merging
    I think the mods should merge these two threads, they are both on exactly the same things:
    this one
  10. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
Thread Status:
