A/V Games console on pc??
Discussion in 'Hardware' started by seebul, 9 Aug 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi, i was wonderin whether any of you guys new wheter i could plug my ps2, xbox etc, into my pc - so tht it would display on my pc moniter ( my tv blew up and i have no money! :waah: )
  2. edz
    edz What's a Dremel?
    18 Aug 2003
    you could buy a vga adapter but the quality might not be that good
  3. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    A TV card in your PC would allow you to view any RCA input.
    I used an old one I got for free out of a friend's disused computer.
    It no longer worked for recieving the TV broadcast but the secondary RCA jack works fine. I just plug my vcr into it and start the TView software I found.
    ATI makes a TV Wonder and there are various other brands out there.
    You could even use it for it's intended purpose and record TV.
  4. woodshop
    woodshop UnSeenly
    14 Oct 2003
    If you got a Vivo card you could do it as well
  5. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    This is the best option, but its not really playing it on PC, just the monitor. Also, using this will give you the best quality possible (A vga adapter) unless you own a LCD tv or HDTV.
  6. brandium
    brandium What's a Dremel?
    22 Jun 2004
    if you want to play console games a tuner/capture card is a good option, but make sure to get one without an MPEG chip. MPEG is great for TV since it saves lots of CPU and HD space, but it has to add a little bit of a delay, making console games impossible.
  7. seebul
    seebul Minimodder
    9 Aug 2005
    Thanks alot guys, i think i will probably go for the tv card thing, so i can record tv to. thanks :thumb:
  8. star882
    star882 What's a Dremel?
    19 Mar 2003
    Wouldn't the data buffering mess it up?
  9. phuzz
    phuzz This is a title
    28 May 2004
    I've got a 6600GT with VIVO, took me a while to find the right drivers (nVidia only released the VIVO drivers for 6-series cards in may), but now the PS2 works just fine, the picture quality looks a bit off, but then thats probably because I'm expecting HL2 type graphics on a monitor, not tv quality. No lag either, so fine for fast games, and I can check my emails on the other screen during boring cut screens :)
    Doesn't answer your question I know, I just wanted to boast ;)
  10. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I got an el cheapo tv card for £25 at PCWorld and play the PS2 on that, the quality is pretty good actually, it plays full screen with sounds.
    You can also get an adaptor to plug in the PS2 straight into the monitor. I've got one, but can't figure out how to get it working!
