Other Games Workshop
Discussion in 'Gaming' started by [ZiiP] NaloaC, 17 Jan 2011.
  1. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Hey guys hoping all is well, the titan is coming along slowly, but awaiting some bits n bobs for it, but in the mean time looking into another project i am trying to light up a model any one good with electronics ?
    scary i studied it at school but in the 20+ years since i left its all gone, Below is the circuit i designed to fit the model but i am starting to rethink it that i might have to go from 3 leds in a row to 2, due to the limitations of the Battery,
    Any help would be greatly appreciated
  2. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    Yup, you'd be best off dropping those strings of 3 down to 2, giving a forward voltage per string of either 3.3 or 6.6 v. 2 x blue LEDs should be more than bright enough for most model scale things.
    For the dual LED strings, you'd need a 120 Ohm resistor in line and for the single LED runs, a 270 or 330 Ohm (bang on value would be 285).
    [ZiiP] NaloaC likes this.
  3. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    circuit (2).png View attachment 49484 New & improved circuit, I found 300ohm they any good ? or am i better with the 330 ?
  4. Almightyrastus
    21 Mar 2002
    300 will be fine
  5. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
  6. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Not really a tabletop matter, but it certainly is related...
    I may have set in motion the final things to purchase an original piece of artwork from Mark Gibbons :)
    Almightyrastus likes this.
  7. Almightyrastus
    21 Mar 2002
    Very cool. When I worked there I had so many opportunities to get original sketches and doodles. Never got any though, I really wish I had.
  8. lilgoth89
    12 Mar 2011
    Current progress on my knights and Warhound Titans
    [ZiiP] NaloaC and Almightyrastus like this.
  9. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Picked up the new shadespire, new Nighthaunt incoming (once I get around to building them)
  10. Almightyrastus
    21 Mar 2002
    More Orkses!!!!!!
  11. lilgoth89
    12 Mar 2011
    Small update to the Titan
    decided to give some upper leg detail markings
    ( ignore the piss poor paintjob )
    Also finishing up on a 27 hour long Upperbody print, the Mk3, with the 'shoulders' and rear vents already modelled on so i dont have to print them separately and it saves a little plastic, also pre-modelled magnet holes for the arm options, i just keep tinkering with the design, this is alredy the third upper, with a visible improvement across the liniage, the Mk 1.5 still have visible print lines and was printed before i had the printer dialed in, the Mk2 is a massive improvement on the Mk1.5 is slightly larger and cleaner, then the newest is the Mk3 with pre-modelled parts
    Next i might move ( back ) onto the shin guards, im already on mk8 or so
  12. lilgoth89
    12 Mar 2011
    Also to add, due to Scaling issues the Lucius pattern warlord project has been shelved, possibly indefinitely,
    but on the other hand, someone posted a high poly model of something else that caught my eye
    will post more images as time passes as a sort of project log here
  13. lilgoth89
    12 Mar 2011
    30 hours in and i have... most of a foot
  14. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Finally managed to get my Ender 3 built up, first prints were a few printer upgrades (filament guides, clips etc). Decided the best way to test out the print quality was an 8mm/Adeptus scale 'warhound'. 12 1/2 hours later!
    It's not perfect but considering the scale (stands 70mm tall) I'm more than happy with it. A little bit of cleaning/sanding and it'll be fine for games at home.
    Almightyrastus and [ZiiP] NaloaC like this.
  15. [ZiiP] NaloaC
    9 May 2008
    Hell that's epic! :D
  16. lilgoth89
    12 Mar 2011
    ^^^ You could almost say its Epic 40k ( Puns,,, i have them ) also my Titan(s) are bigger :p
    the Ender 3 is a great printer, likely the best fdm printer for the money right now if it wasnt for FDM slowly getting encroched by DLP / SLA i would consider upgrading my Wanhao to one
  17. 13eightyfour
    9 Sep 2003
    It would definitely have been quicker/better to print it out on the photon, but I'm waiting on my second replacement LCD for that! :mad: The first one just died, the second decided to only die on half the screen so I can still use it but only for half of the screen. Hopefully, the 3rd one will last longer than a month!
  18. lilgoth89
    12 Mar 2011
    yeah ive head the photon has issues with the screen, didnt realise they were quite THAT bad though...
    also
    HALP
    she is growing !!!
  19. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Only the Omnissiah can save you now...
  20. lilgoth89
    12 Mar 2011
    already taller than my warhounds and growing one long print at a time
