Other Games Workshop
Discussion in 'Gaming' started by [ZiiP] NaloaC, 17 Jan 2011.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    also i never get tired of the infill patterns
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I would be so tempted - if I had the skill - to model fill-channels in that honeycomb structure and fill it with resin after the print.
  3. lilgoth89
    12 Mar 2011
    it wouldnt be to difficult to do tbh, since the bottom is flat you could likely get a paper printout of the infill pattern, drill a small hole in the flat base and use a syringe for the resin
  4. gilljoy
    gilljoy Well-Known Member
    14 Nov 2010
    Folks, I'm looking to get back into 40k after a long hiatus, where's the best place to buy stuff now?
    Also struggling with what to play, I have space wolves and grey knights but I kinda want something new. What are Tau, Thousand sons or the Custodes like at the minute?
  5. [ZiiP] NaloaC
    [ZiiP] NaloaC Well-Known Member
    9 May 2008
    The limited amount of stuff that I've bought recently has all been through GW themselves. I bought one box of Aggressors from Wayland, but it took forever to actually arrive. GW shaft 3rd party sellers on stock, so you can be waiting ages to get the models you spent 10% less on.
  6. lilgoth89
    12 Mar 2011
    im also looking at getting back into playing 40k again...
    i tend to get my stuff from Gifts for Geeks, they have a great range, good discount and ive never had problems with them, although im not sure how they are at shipping to NI
  7. lilgoth89
    12 Mar 2011
    She stands pretty tall... ( excuse the gaps, she is currently held together with Blu-Tac till i can get the pose right )
    Almightyrastus and liratheal like this.
  8. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    Woohooo, lotsa lovins from the GW on my orky skin:
    [ZiiP] NaloaC likes this.
  9. [ZiiP] NaloaC
    9 May 2008
    Current rumour mill on BoLS is that Abaddon will be getting a new model dropped in November.
    I'd still like to see a new Ghaz as well, but seems unlikely now.
  10. Almightyrastus
    21 Mar 2002
    I have heard whispers of a Redemptor sized Ghaz in the works, but that the Ork releases have been plagued by delays, hence the re-boxing of resin kits (such as Ghaz, the Kommandos, and Tank Bustas). How reliable this is, I am unsure as even GW staff are largely kept in the dark. I am not sure how it is now, but when I was at the head office, it was only managers that had access to the studio. The level of internal secrecy and over the shoulder looking before saying anything was oppressive.
  11. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Almost finished some Trees, just need to put a bit of texture paint around the final tree on the left to hide the join in the plastic and paint the stonework the tree is growing around and the rope around the trunk/branches and finally stick some patches of static grass in the muddy areas to stop it being too... brown (although the slate does help break it up a bit).
    GW Trees
    by Blademrk, on Flickr
  12. lilgoth89
    12 Mar 2011
    *cough* nothing to see here *cough*
  13. Mopsi
    Mopsi Member
    12 May 2017
    Those trees looking really great! Yeah some more grass will definitly improve the look.
  14. lilgoth89
    12 Mar 2011
    Very much nothing to see here folks, please move along in an orderly fashion
    current weight : 1.95kg so 2 rolls of filament aka £40
  15. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
  16. lilgoth89
    12 Mar 2011
    i really should leave alone on a project sometimes, while im waiting for a new shipment of filament to continue the warlord i thought to myself,
    Hmm my warhounds shin guards look a little blank ( which was the original intention )
    one thing led to another
    and that ladies and gentlemen is how i arrived at the mk16 and mk17 shin guard files, which are also waiting to go up on the printer
  17. lilgoth89
    12 Mar 2011
    also, givern that my Titan Legion is the Legio Cybranus
    using this symbol
    do you think this works as an extension, this started when someone accused me of being a heretic due to it looking kinda like a chaos symbol
  18. Almightyrastus
    21 Mar 2002
    Fixed it for you, far less heresy now... (and yes, they are meant to now be eagles, yay for half asleep drawings)
  19. lilgoth89
    12 Mar 2011
    Been busy adding all of the polygons!!!
    Roof and rear panels done, arms in place ( and yes they rotate ) also working on adding magnets to all of the things!!
  20. fix-the-spade
    fix-the-spade Well-Known Member
    4 Jul 2011
    If Necrons could feel nervious, I imagine that one would be feeling it now.
