Build Advice Gaming build - Budget $450ish USD
Discussion in 'Hardware' started by silentkillerjoe, 26 Nov 2009.
  1. silentkillerjoe
    silentkillerjoe What's a Dremel?
    26 Nov 2009
    I have an old 19 inch CRT MV920 as a temp monitor lol. Keyboard/mouse/speakers do not need to be included. I'd probably use 1280x1024 or 1024x768 res. I can settle for medium to low graphic settings, preferably medium of course. I'd like to play cod modern warfare 2 or gta iv if possible. I'm in the USA and would prefer to use newegg.
    EDIT:
    I'm definitely willing to overclock, but I hope to have this rig last for 2-3 years.
    2nd EDIT:
    Forgot to mention cd/dvd drives and OS unecessary
    If anyone is interested in some rofl-material I guess? This is what I've been using for everything for the past 5 years http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00574102&dlc=en
    GPU clock oc'ed by 60 mhz.. Ram oc'ed to 200mhz to match fsb. :wallbash:
  2. alex_133
    alex_133 What's a Dremel?
    24 Nov 2009
  3. silentkillerjoe
    26 Nov 2009
    Right on target without the optical, forgot to mention I won't need one. Thank you for the build, lets see what others think/have to offer.. I'm not to great at this, but I've been looking and trying.
  4. Buddharoxor
    Buddharoxor Fubar'd at birth
    6 Feb 2007
  5. ThunderBob
    ThunderBob What's a Dremel?
    19 Sep 2005
  6. bagman
    bagman Minimodder
    18 Apr 2009
    yes the e5200 overclocked is a very good chip but it has no future you won't be able to upgrade in a years time better to go for amd now and it will pay off later
  7. docodine
    docodine killed a guy once
    10 Feb 2007
  8. silentkillerjoe
    26 Nov 2009
    I got $555.44 before shipping from that build.. But thank you.
    EDIT: Ahh nvm, different gpu.. With the PNY GTS 250 I got $475.44 before shipping.
  9. docodine
    10 Feb 2007
    There's a rebate on some of the items, total with shipping should be around the same as the total after rebates.
  10. silentkillerjoe
    26 Nov 2009
    This is what I've come up with, I'm not sure if its all 100% compatible. I would like to get an extra fan for the case, but I don't know how many the mobo can power. I am willing to change any part I have listed here. I want to overclock the hell out of it, even the ram to 1066 plus the video card if I can. So if anyone can help me figure out if I can play what I want, if it will all work, if I can get a better deal etc.. Thank you in advance ;)
    Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147135
    MOBO - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128388
    CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
    HD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
    VIDEO - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339
    PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
    RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
    Total - $510.44 :(
  11. alex_133
    24 Nov 2009
    I'd seriously consider going AMD here.
    LGA775 has little to no upgrade path.
    AMD Athlon II X2 250 + ASUS M4A785-M = $132
    Intel Pentium E5200 + GIGABYTE GA-G41M-ES2L = $129.50
  12. alex_133
    24 Nov 2009
    2nd shot:
    Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147135 (Same one you picked out, thought you might have liked the looks of it)
    Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131595 (Simply can't go wrong with AM3 socket + 785G chipset + ASUS)
    CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103681 (You could probably get this puppy up to ~3.9GHz if you wanted, that's E5200 territory)
    PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008 (Rock solid)
    RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184 (Works great right out of the box, no need to mess around with it's timings, voltage, etc)
    Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369 (Forget the 128-bit memory interface, this card beats the 9800 GTX+ @ stock for ~$20 less, overclocks quite nicely, plus... you gotta love the fan)
    HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073 (WD, 16MB Cache, 500GB, 7200 RPM, SATA II)
    Total: $482.94
    http://img691.imageshack.us/img691/3545/rawrd.jpg
