Peripherals Gaming Controller
Discussion in 'Hardware' started by Kehoe, 28 Mar 2016.
  1. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Hi People,
    Recently been having a major tidy up and came across
    Id totally forgot i had it, now it was for the original xbox, which no longer have, some reason i kept this, looking online their is a means and way to get it working on the USB, but i cannot for the life of me find the cable i would need online, any suggestions, Also i need to try and replace on the left column 1 of the toggle switches' and the thumb stick, Thumb stick is easy found an old PS2 controller cut it off that and stuck it on with glue and a bit of pain but the toggle switch the bit of plastic that pokes through is missing and i've not got a clue off top of my head what id need to do to fix/ replace this
    Any advice or help anyone can give on this, reading online looks like its a pain to get setup but once setup you can have some major fun in games.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  3. Blogins
    3 Aug 2010
  4. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    ahh thanks, see my only concern is that cable is 20" and they advise no longer than 3" i'm struggling to find a smaller one, still hoping somewhere i can find the Xbox part of the controller as atm its the round pin, the bit that connects to is missing, still then need to get the toggle switch repaired.
  5. Vault-Tec
    30 Aug 2015
  6. Blogins
    3 Aug 2010
  7. Blogins
    3 Aug 2010
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    The XBOX uses USB with a special plug, so you can just cut off the XBOX plug and replace it with USB.
    You'll find the wires follow the usb standard so it's super simple to do if you can solder.
    USB PINOUT KEY
    1. +5v
    2. -DATA
    3. +DATA
    4. -5v (Ground)
    XBOX PINOUT KEY
    1. -5v (Ground)
    2. +12v (Unused)
    3. +DATA
    4. -DATA
    5. +5v
  9. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    not soldered in many years but i do have everything i need to do, just need to dig out the gear, my only concern is if i bugger it up i've then got to find a new Usb bit has the current connection is a round *looks like Ps2* type connection and i've only found 1 old school xbox adapter,
  10. stephen0205
    stephen0205 Minimodder
    11 Mar 2016
    that is possibly one of the coolest things ive seen
  11. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Will be even better if i can get it repaired and working, only predicament i have their is 5 toggle switch's look easy to switch out *fingers crossed* only one is broke do i just replace that *never going to find a replacement as they are plastic and look like they where designed for the unit* or do i replace all 5 so at least they are matching and if i was to replace they would be metal not plastic.
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Ah it's got a breakaway cable, that makes things much easier, the 'ps2-style' end of the cable looks the same for XBOX and XBOX 360:
    http://www.ebay.co.uk/itm/Hellfire-...way-Cable-Lead-for-Xbox-Original/291290178248
    http://www.ebay.co.uk/itm/PC-Comput...er-for-XBOX-360-Wired-Controller/281958121434
    Might be worth a punt for £1.79? Or buy both and then modify them and not your original cable?
