Build Advice Gaming machine
Discussion in 'Hardware' started by AQNFX, 12 Mar 2009.
  1. AQNFX
    AQNFX Twist The Grip, Let It Rip!
    17 Jul 2008
    Okay, I want to build a gaming machine. I kind of want to go with AMD. but as everyone should know is that AMD is losing its grip on the chip world. And AMD MOBO is lacking alot good features. I know that the i7 is good and all but still not worth the price and i5 is suppose to be out around mid summer.
    I like ATi cards too.
    So what should i do?
  2. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Um, what's wrong with your current computer?
  3. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Wait until summer for i5?
  4. bigspin
    bigspin What's a Dremel?
    20 Feb 2009
    Your current machine is fine. Keep it until Core I5
  5. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Exactly. A 4870x2 and 3.2GHz dual core is perfectly fine for gaming!
  6. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    Agreed. If you're desperate for an extra speed boost, your best bet is probably to sell off the Raptors and go SSD+HDD. Maybe do an in-place CPU upgrade to a Q9550, maybe. But when your system already looks like that, really, why would you be looking to replace it in its entirety? It will not be worth the extra cost. Period.
    - Diosjenin -
  7. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    +1 on that, the only upgrade I can really see for a decent (relatively cheap) speed boost would be faster RAM (1066MHz+), but even then you're forking out £50 for a performance upgrade you won't really notice
  8. AQNFX
    17 Jul 2008
    when i build new this computer my old computer will be turned into a HTPC. The video card will be moved to its new home.
  9. Diosjenin
    14 Jul 2008
    That makes more sense.
    I'd wait for i5 if I were you. At the very least, you'll get to see whether it's worth however much it'll cost, and if it isn't, at least the prices on everything else will have dropped.
    - Diosjenin -
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Definitely wait. There's absolutely nothing that is reasonably priced and will give you a real improvement.
