Windows Gaming Mouse
Discussion in 'Gaming' started by Houck, 1 Mar 2007.
  1. Houck
    Houck What's a Dremel?
    11 Jul 2006
  2. cjmUK
    cjmUK Old git.
    9 Feb 2004
    It's ok as a budget gaming mouse... I'd personally stretch as far as a Razer Krait or Diamondback which are both 1600dpi (both <£30). There are plenty of other good mice out there but many are £30 - £60.
    <edit>
    I'd also invest in a suitable mat. I have the Razer Mantis Control mat which is about £15.
    PS I'm not a Razer fanboy; there are loads of other good makes out there at similar prices.
    </edit>
  3. Houck
    11 Jul 2006
    cool I am looking at some of the razor stuff now. I will look for a good mouse mat as well. thanks
  4. Houck
    11 Jul 2006
  5. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Shop around... I'm sure I paid less than £15 for the mat...
  6. Houck
    11 Jul 2006
    It's ok. My mam will not buy from the net, so computer is my local store. I got the money anyways.
  7. Axel
    Axel What's a Dremel?
    20 Feb 2007
    Razer Copperhead or Salamander,depending on the money you have.
  8. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    Logitech mx518 here, it's an amazing mouse. £30.
  9. matt.slysnake
    matt.slysnake Banned
    27 Dec 2006
    Same here, it has 2 buttons on the side but they don't get in the way at all, + you can set hotkeys to them. I've had a go with a razor diamondback, and I didn't like it compared to mx518
  10. Onyx
    Onyx What's a Dremel?
    13 Jun 2006
    haha thats cool. im still using my old logitech mx510
    I got it in 04 back when it was the best mouse out.
  11. Houck
    11 Jul 2006
  12. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    Logitech G7
    Has gone up a bit in price though since i brought it
  13. Seth
    Seth What's a Dremel?
    14 Mar 2002
  14. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Got an mx518 here, pretty solid mouse, though I think maybe could be a touch larger for my big hands.
    On headsets I have been hearing good things about the medusa set (supposedly good 5.1 surround plus a proper mic and not that badly priced)
  15. Major
    Major Guest
    Ditto
    I have the G7 for sometime. Amazing mouse. If your an FPS player. This IS the mouse for you. Accuracy is amazing, tracking is perfect, I didn't relise how crap my last mouse was until I got this, Heh. Don't worry about the battery life, it comes with two, one is in your mouse, the other is charging, if your midgame and it cuts out (Will give a warning way before), just swap them over and your sorted for a few days.
    GL ;)
  16. Kurayamino
    Kurayamino As long as the Raven flies
    5 Sep 2005
    Logitech G5 here! Awesome mouse love that you can switch down the DPI instantly helps in FPS :D
    G5
  17. Kurayamino
    5 Sep 2005
    Do you think thats because you bought it? Word got out :thumb:
