Build Advice Gaming PC - £500 Budget
Discussion in 'Hardware' started by TheCrimsonSheep, 29 Mar 2012.
  1. TheCrimsonSheep
    TheCrimsonSheep What's a Dremel?
    29 Mar 2012
    Hello all!
    I'm here seeking advice on a gaming PC that I'm hoping to keep at around £500
    So far I've compiled a reasonable list of components but I'm trying to get a better processor for the money, I'm definitely up for overclocking aswell :D
    On a side note I'm also spending another £100 or so on a HD montor, so my resolution is gonna be 1920 by 1080 for gaming =)
    So to summarise:
    Budget: £500 - £550
    Main uses of intended build: Gaming
    Parts required:All - total system
    Monitor resolution: 1920 x 1080
    Storage requirements: 250 - 500 GB
    Will you be overclocking: yes
    Any motherboard requirements: Wouldn't mind trying to squeeze in a USB 3.0 port or two =)
    Extra information about desired system: I'd like the absolute best gaming performance I can get for this money XD - Somewhere around a GTX 560 ti or perhaps even a radeon HD 6950 if I could get it in =p
    Thanks for any and all advice =)
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Does the £500 need to include Windows?
  3. Shirty
    18 Apr 1982
    I'll let the build expert junkies advise you on the contents of the rig, but for £100 I'd recommend going second hand on the monitor. You should be able to find something in that price range that will be a huge improvement over a cheap no-brand new model.
  4. noizdaemon666
    15 Jun 2010
    Removed cos I don't think my brain was switched on when trying to put a build together :p lol
    Also for monitor, the BenQ G2222HDL is probably the best you'll get for ~£100.
  5. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    Hows this?
    yet again you will be stuck using stock cooling until you can gather some more funds, you might be able to get away with a slightly lower wattage PSU in which case your could get and aftermarket cooler or a better case.
  6. noizdaemon666
    15 Jun 2010
    I'd go for mrMonkeyChunks build. Though £9 over budget it is far superior to the one I did. (I tried to stick rigidly to the budget :p lol)
  7. Parge
    16 Jul 2010
    MrMonkeyChunks build is solid. He's got all the power where it counts, decent RAM, a nice case and a reliable motherboard.
  8. noizdaemon666
    15 Jun 2010
    You saying my build doesn't????? *waves fist angrily* :p
  9. adam_bagpuss
    24 Apr 2009
    monkey chunks build is good spart from the HDD which really needs changing for a decent 7200 rpm drive. the WD 500GB cavier blue is £60 from scan. The 2.5" 5400rpm will be painfully slow
    Also you could drop the case and PSU and grab the coolermaster elite 334U which inlcudes a coolermaster 460W PSU this should still be enough. PSUs only hit best efficiency at 70-80% load anyway.
  10. mrMonkeyChunks
    4 Mar 2012
    If you can afford it you really should get the hard drive bagpuss suggested, I was just trying to remain as close as possible to the budget.
    The 460W PSU should be enough but if you are looking to upgrade in the future it might be worth getting the extra watts.
  11. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    for a monitor try [url="http://www.scan.co.uk/products/215-lg-ips225v-bn-black-full-hd-led-ips-monitor-1920x1080-5ms-250cd-m-50000001-vesa]this [/url] it is very very good the colours are great its £126 so over a little
  12. noizdaemon666
    15 Jun 2010
    TobletDanillio; your link is slightly wrong. It should be this ;)
    And undoubtedly that would be better for colours than the BenQ though it is over budget.
  13. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
  14. mrMonkeyChunks
    4 Mar 2012
    Correction: Damn you VAT ;)
  15. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Damn you VAT indeed.
    Im just giving a second vote to Mrmonkeychunks suggestion seems like the best for the money. I would say look at the bit-tech buyers guide but they seem to have stopped now so are woefully out of date.
    still might be usefull for a base idea possibly :/
  16. immoral
    immoral What's a Dremel?
    21 Mar 2010
    Definately go for a 2500k (unlocked) as mentioned above and 2x4GB 1600Mhz XMS3.
