Modding Gatewatch + Drive Rails = $70 paperweight ?
Discussion in 'Modding' started by khendar, 19 Apr 2006.
  1. khendar
    khendar What's a Dremel?
    25 May 2004
    I've a slight dilemma. I've gone and ordered an Aerocool Gatewatch controller/display, and stupidly didn't think to check if its going to fit in my Antec SLK3700 BQE case - which utilises rails for 5.25" drives.
    Anyone attempted to install one of these things in a case with rails - if possible, specifically this case ?
    Cheers.
  2. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    no, but the holes on it dont line up with the holes on the locking mechanism in the Centurion 351 either..you have to attach it on one side only :(
  3. Bubolzm
    Bubolzm What's a Dremel?
    16 Apr 2006
    i would say if you cant find a way to attach it, RMA it and get your money back.
    if they ask for a reason, say incompatibility.
  4. khendar
    25 May 2004
    Well, I received this in the post today and managed to get it fitted. Just attached a pair of rails and locked it in. Its a little bit dodgy because I can only get one screw in each side due to the placement, but it seems sturdy enough. Its not as if its heavy.
    So yay..more pointless rice for me :D
  5. mattthegamer463
    26 Nov 2004
    Maybe if you put it in the bottom 5.25" bay (so its resting on the metal thats at the bottom) and then screwing in as many screws as you can get in, that should be fine. I do that with hard drives all the time, because when I use a old case that only has one hard drive mount, but I want some extra drives, I stuff them into floppy slots (where the holes don't line up) and they stay in place pretty well.
