GatewayRising- A Sleeper! --Updated newer pics---
Discussion in 'Project Logs' started by Defyant Mods, 19 Jan 2005.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I love the thought of SLEEPER PC's ones that look like old shitters but are
    beasts inside
    So heres my current rig and my fav mod of all :p and older mod.
    Its also an old skool-P2-350 but this one is Gateway tower....
    I found a bunch of these in a colex bin all in perfect condition with full hardware inside.
    I loved the size shape/design and solidness of the case you can beat these old towers for build quality.
    It all begins somewhere!!!
    As you can see shes Plane-Jane, but thats perfect as i wanted this to be a sleeper PC ... i have plenty of fully modded pcs to show off so i wanted a Sleeper PC to have fun with @ lans!!!
    Guys! this was a quick MOD 3 hrs max to knock this up......
    There she is boring old beig! nothing special to look at.
    The best feature of the whole case if the large air duct area in the front! this can be opened up some more and will be perfect for 2 x consealed 120mm BIX extremes :)
    Also a comparrison of the chassis after a full rub back modded and 2pack Silver metalic paint job.
    All fans were rubber "O" ring mounted to stop vibration and case noise!
    Next was to start on the front duel Rad installs.
    Old denko were hacked apart and used for spaceres :eeek:
    Floppy drive bay was binned to fit the duel setup
  2. Defyant Mods
    14 Sep 2004
    Next was to dress up the insides a bit, an idea i've had for a while was to utilize coloured perspex (plexi) i had some green laying around forn an old mod so its being used.
    OOPS! and a peek at the beast within!!! :eeek:
  3. Defyant Mods
    14 Sep 2004
    Had an old areogate laying around so thought i'd incorp it in as well.
    not wanting to take away for the standard look i opted to graft it into on of the original facia panels.
    YES!!! the original Intel PII sticker stays!!
  4. Defyant Mods
    14 Sep 2004
    The 2 top mounted 80mm alu evercools will need holes to breath thru as will the top T bleeder for the water setup! holes where cut and mesh was shaped to fit.
  5. Defyant Mods
    14 Sep 2004
    Last was to fit up the hardware! as per sig! a duel Xeon 3.2 @ 3.7 running water with a 6800u
  6. Langer
    Langer Jesse Lang
    24 Jan 2004
  7. Defyant Mods
    14 Sep 2004
    Here she is! very un-assuming Sleeper PC ! a Wolf in sheeps clothing
    Cheers!
    Youd never guess!!!!,
    Altho maybe the 20 and 23" LCd's might give a hint!
  8. Arne
    Arne What's a Dremel?
    1 Jul 2004
    indeed :cooldude:
  9. Defyant Mods
    14 Sep 2004
    Soz lang what part mate?
    EDIT: you mean the bottem pic?
    The external T bleeder for the water,
    Because this is my main rig atm and i take it to lans etc, i didnt want to have to open the case to air or water bleed or fill, this was the best solution to get around this and always gets ppl's attention :)
  10. DoNuT
    DoNuT What's a Dremel?
    20 Dec 2004
    Looks good, I love green plexi! Are you gonna paint it?
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    oops, should have looked at the link first.
    The very last pic
  12. Defyant Mods
    14 Sep 2004
    NOOOOOOOOOOO!!!!! never its a sleeper! ive got other mods to show off my painting prowless,
    this will never see a drop of paint.......
    Lang i edited the last post to help explain the remote T bleeder :)
  13. th3ory
    th3ory What's a Dremel?
    13 Dec 2003
    v noice work u did there
    cant believe u found several of these cases in the bin
    do u have other mods planned for the rest of the cases or r u just gona chuck in your garage or similar and leave them for ages like i do when i find cases like that?
    :cooldude: harry
  14. Defyant Mods
    14 Sep 2004
    Thanx mate :) yer like you, i stack em in the back of the garage till i get inspired,
    I'm thinking with the second one i might give the panels a HPRESII type makeover and keep it just to interchange parts :D
    Atm tho i cant see me touching this one! its hard to find them this old in such perfect condition.
    EDIT: that current project of yours is looking awsome!!!
  15. kobaj
    kobaj Banned
    4 Jul 2004
    Nice, but I sorta dont like the fact that you used green plexy for a window. It sorta defeets the perpose of having green plexy on the drive bays/other. I would have gone with clear. Yes I know that you only had green but...Nice mod enywho, I like the way you piped it... but why did you die the water if your window is green. Now for a nice mod I would like someone to use painted uv pvc instead of flexable...ooo and if I could remember the other real cool loooking substance that would look so freaking awsome I would tell you.
  16. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    Very nice indeed. Been thinking of doing this to a dell...
  17. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    YOu never cease to amaze me!
  18. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    How have you secured the mesh vents on the top? Just hot glued?
    Nice sleeper. I agree on the comment about the green window though.
  19. Crazy_Seb
    Crazy_Seb What's a Dremel?
    15 Jun 2003
    Where the hell are your hard drives? I see 4 hard drives in your sig but i don't see any hard drives in the pics? :confused:
  20. Defyant Mods
    14 Sep 2004
    Hey contructa!
    Yer mate just hot glue, modders best freind :)
    2 x 200's on rubber mounted slugs under the cdroms
    2 x 160's on external firewire
    1 x 120 + 1 x 80 in server
    and 2 x 160's in my son Zak's Pc
    dammm is that a terrabyte??? :eeek: :eeek: :eeek:
