Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'm only 5000 off at stock! Woo!
    But seriously. HwMonitor needs fixing.
    My processor is at 16.5 idle, not 4.
    Although holy crap. Under Cool & Quiet (0.95V, 1.4ghz) my processor is apparently only 1.5 degrees hotter than the intake temp.
    It's alarming when scrolling down a webpage causes a four degree jump, though.
  2. Guest-44432
    Guest-44432 Guest
    I will add some pics when it arrives..Still not here...13:30???
    On the phone now giving...a Calm voice, as Roaring, won't get me anywhere...Now given me a full refund on delivery, Thank you. But I want my PC now...Having withdrawals...lol
    3lusive likes this.
  3. .//TuNdRa
    12 Feb 2011
    Okay. It's not a good sign when Overdrive goes into the red at 1.5 volts, and only goes as high as 1.59V before it refuses to let you select any higher.
    Bios overclocking it is.
    Seems this processor's thermal floor on air is 15 degrees, though. Getting 35 degrees max, however. Makes it almost worth not being able to feel my toes.
    Edit:
    Nope. This board will not do 5ghz, nor will it do a 2775 mhz HT and NB speed.
    Seems I'm more or less at the limit. That was fast.
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I probably won't get chance to fully OC my rig for a week or two as Im going to be busy till the new year. Going to double check my settings and try and get it above 4.5ghz and see what happens.
  5. .//TuNdRa
    12 Feb 2011
    Sweet. I'll bench this thing again soon as I've got 1600mhz memory. See if I can't climb a bit higher up that leaderboard.
    Managed to get this thing stable at 4.125ghz, though. Seems to be happy at the moment, doesn't go above 47 too. So i've got a nice buffer before that thermal cutout.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You'll go lower I'm sure :p
  7. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Well for some odd reason I got a BSOD after double checking my settings and increasing the OC from 4.5 to 4.7.
    I loaded Optimized defaults as I think I will leave the OCing to the big boys and girls :)
  8. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Just got the 990X up and running and did a quick bench on my first boot @ 4.5GHz - ignore the frequency reported by Geekbench (no idea where it gets 4.69 from...)
    15205
    A LOT more to come from me once I've tweaked this biatch to the nines :thumb:
  9. .//TuNdRa
    12 Feb 2011
    It's more a case that it passes everything I throw at it, then I yell "Woot! It's stable!", then it crashes and refuses to boot for a while.
    As is; I'm not That far off stock voltages. I'm up a touch on NB and HT voltages, but that's because they're higher than normal, at 250 base HT speed.
    Processor's only gulping down 0.175 extra volts at the second, so I'm not going to fiddle. Might whack it down another .025 later to see if it's happy at that.
  10. Guest-44432
    Guest-44432 Guest
    I want you to beat my best, but it was only set at 4.7Ghz:D
    Edit: Very very angry now...Still no delivery...oh the rage!!!!:wallbash:
  11. .//TuNdRa
    12 Feb 2011
    Oh man that sucks.
    They'd best give you more than a refund for the delivery for this crap.
  12. Bloody_Pete
    11 Aug 2008
    Couriers don't give a sh*t, had so much of this cr*p at my old job...
  13. Guest-44432
    Guest-44432 Guest
    I would have been benching by now...(Oh wait till the driver comes to the door).:wallbash: You call this before noon?:wallbash:
  14. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    If he comes... :jawdrop:
  15. Guest-44432
    Guest-44432 Guest
    Damn you, you want to curse me?
  16. .//TuNdRa
    12 Feb 2011
    Couriers don't give a toss because they're self employed most of the time. It's why I have so much difficulty with DPD half the time.
  17. shaunster1011
    26 Sep 2011
    Nah, ive just had it all before, pay for before 12 and it doesnt come and then they end up delivering it the day after before 12.
  18. Virus44
    Virus44 What's a Dremel?
    2 Nov 2011
    doesnt mention my motherboard or the cpu speed for some reason which was at the time 4.3ghz and the motherboard is Gigabyte Z68AP-D3 could you add this to the chart ?
  19. Pookeyhead
    30 Jan 2004
    Did it arrive?
    Will do.
  20. .//TuNdRa
    12 Feb 2011
    I really should try and find out which of those two modules is dud... I could probably up my score a touch more by having more than 8GB in the system when I bench it...
