Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. law99
    law99 Custom User Title
    24 Sep 2009
    Have you overclocked your memory or tightened the timings for geekbench? Or are you just going to be stuffing some new modules in asap?
    Still pretty good for the money eh? You could have bought 2 for the price of my one by now, maybe even 3 and run them into the ground!
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    True.
    I haven't done anything with my current memory, it doesn't respond well to even a tiny increase in speed. The 4000 memory score was just having a faster NB & HT speed for the test.
  3. law99
    24 Sep 2009
    are they failing memtests? I was hoping I could have eeked out 8-8-8-24 but couldn't. They aren't so versatile.
    My old single core linux machine had some really overclockable memory back in the day. Used to be able to run them at 1066 rather the 800 and they were cheap and cheerful value ones. I hate blind luck :( But that's half the fun eh?
  4. .//TuNdRa
    12 Feb 2011
    More Not booting at all if I try.
  5. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    @pookey when you get back after christmas, don't suppose you could update my 64 bit scores :)
  6. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    I tried this out of curiosity. I didn't feel like buying it so I only got a 32-bit score.
    First specs, ran on my laptop:
    Asus G73SW
    CPU: i7-2630QM @ 2.0GHz (but is subject to Turboboost)
    Memory: 8GB DDR3 666MHz
    GPU: GTX 460M
    Mobo: Whatever comes with the laptop :p
    Score: 8302
  7. law99
    24 Sep 2009
    Beaten by a laptop... :wallbash: great. lol.
    Upload your results? I think cpu my gf has in hers. I'll try it when I see her.
  8. David
    7 Apr 2009
    Jaybles likes this.
  9. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
  10. Kernel
    Kernel Likes cheese
    29 Sep 2003
  11. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    You and your bloody water! :D
    Wednesday its gonna hit 3 degrees. With a bit of this :dremel: and a bit of this :brrr: I will be hunting you down!
  12. David
    7 Apr 2009
    It was getting very toasty at 4.53GHz, so I've upped the fans to 12v.
    I may go for a glory run if the kids will leave me alone long enough.
    It's getting difficult now though, I reckon I'm getting near the limit of the board's QPI ; and maybe the CPU's ceiling.
    Damn you and your 23x multiplier! :D
  13. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    I'm only using a multi of 21 atm for 4.42 GHz but I was hitting 90s during Geekbench. I didn't bother with prime or any stress test because I'm pretty sure I'd hit the thermal ceiling and it would just shut it off.
    I've got my eye on one of these though so I will be after you soon.
  14. phidelta42
    phidelta42 What's a Dremel?
    26 Oct 2010
  15. David
    7 Apr 2009
    So you still have some headroom with decent cooling. :thumb: Damn!
    No! You can almost buy a Corsair H100 for that!
    Clicky
  16. thetrashcanman
    18 Nov 2010
    But the Phanteks is much better than the h100, almost as good as an NH-D14, although at £70 your probably better of going with the NH-D14 as I think it's at least a fiver cheaper and slightly better cooling performance than the Phanteks.
  17. David
    7 Apr 2009
  18. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    nice job on getting past 12k..... i still need 300 odd points for 12k......
  19. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    From the review I looked at its better than the D14 and H100. And also if I got a H100 then i couldn't say I beat you with air cooling, Spreadie :D
  20. thetrashcanman
    18 Nov 2010
    Ah yes I re-watched the review that TTL did seems the Phanteks begins to pull ahead of even the NH-D14 when you start using crazy volts :D
