Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Bring it, biatch! :hehe::hehe::hehe:
    I'm fairly impressed, actually.
    Not just the score - I managed that with much lower CPU and QPI volts than I expected.
    Thanks for the nudge in the right direction, Lenny. :thumb:
  2. lp rob1
    lp rob1 New Member
    14 Jun 2010
    Ubuntu One thing first - I had a brain fart. By default the Software Center is there on the left, but it's got a kind of packaging cardboard box icon with the Ubuntu logo in one corner. EDIT: That's just my theme changing the icons. Looking at your screenie (in the FUTURE!) its the suicide bomber bag with fireworks coming out of it.
    When you have extracted the files (assuming in home/Downloads/dist) then open a terminal then type 'cd Downloads/dist'. That will get you into the dist folder. Then type 'ls' (that's an L, like lprob1 :p) or look in the file manager to see what folder you need to get into next. For me it was 'Geekbench-2.2.3-Linux'. Notice the capitalization. So type 'cd Geekbench-2.2.3-Linux'. Now you are in the folder with the executables, so just type './geekbench_x86_32' to run it. A useful tip while using the terminal is that Tab autocompletes the command or file that you are typing. So in the first 'cd' you could type 'cd Down' then press Tab, and 'loads/' would be automatically filled in. Then 'dist/Geek' and Tab results in the rest of the 'Geekbench-2.2.3-Linux', without actually having to type it in. And finally './geek' +Tab will give you './geekbench_x86_', but not the 32, because there are two executables (denoted by the ./) that begin with 'geek', so just finish it off with the 32 and press enter.
  3. Pookeyhead
    30 Jan 2004
  4. lp rob1
    lp rob1 New Member
    14 Jun 2010
    Or you can do that :D
    Also wanted to add that for some reason integer performance is better on Windows (comparing LennyRhys's 920 against mine [930 that is, but little difference]) yet floating-point is better on Linux?
  5. Pookeyhead
    30 Jan 2004
    Yep.. Integer is down on that Linux run, yet floating point is off the scale.
    "CD" does not seem to work with any directory at all. :(
    At least I have a working Linux install now. I've configured the BIOS in such a way that I shut down.. plug in the drive with Linux on it into the hot swap bay.. restart.. and I'm in Linux. Shut down.. remove drive... restart... back in Windows.. sweet! Not that I have a use for Linux... but it's still cool.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    my laptops score
  7. David
    7 Apr 2009
  8. Pookeyhead
    30 Jan 2004
    what ram speed, and how much RAM please? Can't put it on the board without all the info.
    Charts fixed and updated.
  9. Pookeyhead
    30 Jan 2004
    Full screenie, or preferably a link please. Can't really read that.. way too small.
    Geekbench is terrible at reporting clock speeds too, so can you please either include a screenie of CPU-Z or just tell me what your clock speed is.
  10. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Very impressive.
    The best I can do with my 920 is 4.4GHz with 2100 mem and 4200 uncore, might net me 12.5K but I'm not sure.
  11. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Should have a new score in a minute, will add then.
  12. Pookeyhead
    30 Jan 2004
    LOL... That will be the 3rd time I've updated them! Damn you all.... go outside and play!
  13. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Just wanted to get my name in over 10,000 before going for my highest. :p
    Note that CPU-Z has the correct CPU speed, Geekbench just records the default.
    EDIT: On air.
  14. David
    7 Apr 2009
    I know there's more in there - the board's QPI will go to 220 ish, with plenty of volts. But it's more about finding a balance, isn't it? I ran it at 4.55GHz but the memory bandwidth dropped off a bit. Clearly some instability crept in, but not enough to kill the test or halt the system.
    I think she'll do 12.5 maybe 12.6k, but she'll be scary hot.
  15. RichCreedy
    24 Apr 2009
    Linky to full screen shot
    cpu-z showing slowed down speed, it did actually run at 1.99Ghz
  16. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    I'm sure if I push it i'll get better score but for 1156 it's plenty.
  17. Siwini
    14 Sep 2010
    I see I'm in the lust. Nice Pookey.... One thing you might want to change from air to water:)
  18. SeñorTasty
    SeñorTasty New Member
    19 Jul 2011
  19. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Damn it! I haven't checked this thread in a while, but now I have, I find Siwini has usurped my leading of LGA1156 :jawdrop: Can my i5 possibly beat his i7? Only one way to find out........MOAR VOLTS!!!!!! :D
  20. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    POWWWWWERRRRRRRRRRRRRRRRRRRRRR!
