Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. bulldogjeff
    2 Mar 2010
    Just had a look, thats still a good score, but that program is all so very memory based and running the 32 bit program won't give you a true reading of you rigs capabilities.
  2. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    nah it was 64bit :(
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Bios settings and a dozen other factors can also impact. Disable anything like SpeedStep while you're testing, you'll have lower latency, rather than the faint pause in the time it takes for the CPU to scale back up to full speed.
  4. j4mi3
    28 Jun 2011
    should i disable both turbo and speedstep? i think i only turned off speedstep
  5. .//TuNdRa
    12 Feb 2011
    Turbo is going to spin around a bit. it'd be better if you could achieve a higher overall speed, I think.
    In other news: I have added, like, seven points to my score! http://browse.geekbench.ca/geekbench2/561316
    Inch by screaming inch; I'm going to get 13k. Processor was at 4977mhz, Memory at 1580Mhz.
  6. j4mi3
    28 Jun 2011
    was this 32bit or 64bit?
  7. .//TuNdRa
    12 Feb 2011
  8. j4mi3
    28 Jun 2011
    lol wat thats nearly as good as my 4.6ghz 2600k. awesome
  9. .//TuNdRa
    12 Feb 2011
    Still can't hit my 13K goal, though. Bulldozer's crappy Memory Controller really isn't helping me here.
    Still, not bad for a good fifteen minutes of work. Back to raging at games now.
  10. j4mi3
    28 Jun 2011
    you play bf3? add me names in sig
  11. .//TuNdRa
    12 Feb 2011
    Not bothered with BF3. I'm too much of an Introvert to bother with teamwork.
    Sidenote; This processor doesn't actually mind 1.725V if the need arises. Who'da thunk it?
  12. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I find this interesting, along the same lines as something bulldogjeff said in another thread AMD chips seem happy with whatever volts so long as you can tame the heat
  13. .//TuNdRa
    12 Feb 2011
    Up to a certain point, aye. Beyond about 1.775; Water Cooling starts to become a bit iffy. You need DICE or stronger to keep it in check afterwards.
  14. law99
    law99 Custom User Title
    24 Sep 2009
    have you bumped your base clock for extra memory speed? You may have to drop you multi as you go.
  15. j4mi3
    28 Jun 2011
    hmmm i did raise it to 101 i think, i might try it higher next time
  16. law99
    24 Sep 2009
    Mine happily raises to 105. As its memory sensitive, moving your baseclock also overclocks your memory. So you'll get a higher score. But it also overclocks your CPU x multi, so you have to balance clock speed against memory speed.
  17. j4mi3
    28 Jun 2011
    yeah i know :) unfortunately mine doesnt seem go higher than 103.5 which is what i use for 24/7
    i will trying upping it to this and balancing multi/bclk next time though
  18. jizwizard
    jizwizard Modder
    24 Dec 2010
    Get that chip wound up j4mi3
  19. Tangster
    23 May 2009
    Got me beat. I could probably push to 5.4GHz, but I'm gonna be busy with the ME3 demo. Nice one Tundra:thumb:
  20. law99
    24 Sep 2009
    I didn't bother with half steps. I put my multi to stock. Then raised baseclock as high as it would go, and afterwards raising multi. (I tell a lie. I put multi to 40) I hit voltage wall first. Before I found the high clocks. I was v.upset. need a better mobo. It was something i did not forsee.
