Windows Geforce 2 : is this enough?
Discussion in 'Gaming' started by RPC_Student, 13 Jul 2004.
  1. RPC_Student
    RPC_Student Banned
    8 Oct 2003
    ...for Deus Ex 2
    (I'm assuming no, but if I can delay the purchase of a new graphics card before deciding on an entire new PC system, then all the better)
  2. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    The only specs I found didn't say anything about needing any kind of graphics card (said "3D card" :rolleyes: ), so it will probably work. But I would deffinatley recomend a newer GPU.
    L J
  3. Guest-16
    Guest-16 Guest
    probably, 640x480 or 800x600 no AA/AF. Try it n see, if it turns into a slideshow then just play it when you have more beef.
  4. RPC_Student
    RPC_Student Banned
    8 Oct 2003
    on the box, is says "GFX card must support pixel shaders". I'm not sure Geforce 2 cards do...
    I need to buy a DVD drive to play the game anyhow, so I might end up upgrading my entire system, but I'd still like to know "for sure" before splashing out.
  5. Guest-16
    Guest-16 Guest
    Dues Ex 2 is CD isnt it? or i know there's a CD version..
    GF2 does have pixel shaders - was the first card to have it. GF3 had vertex shaders too and GF1 had T&L.
  6. Jedi
    Jedi What's a Dremel?
    16 May 2004
    yes i believe dues ex 2 comes in cd flaaaava!!
    it'll never be as good as the original :grr: :grr:
  7. RPC_Student
    RPC_Student Banned
    8 Oct 2003
    I'm sure DX2 wont be as good as the original -- thats why I waited for the price to drop - I got it for $21 on play.com (£12.99). Unfortunatly, I didnt notice it was a DVD-ROM. though it is a good excuse, I've needed a new drive for ages
  8. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    i have a GF2mx and specs in my sig. I can run UT 2004 at medium quality at a very playable fps (perhaps, 20-30). It cant do AA or ASF but it still works well. If your only bothered about gameplay then it will work. Ther only game i have never been able to run on this baby is kriegger! Im anticipating doomIII will take a while, but itll run :)
