Graphics Geforce 7900GS or 7600GT? i cant decide
Discussion in 'Hardware' started by morris8809, 30 Dec 2006.
  1. morris8809
    morris8809 Minimodder
    30 Dec 2006
    Hello i am building a budget pc but i am trying to get the most performance vs. cost. I cant decide which of these cards to get. If anyone can taell me how good these are compaired to each other please do so because i need help deciding. Thx
  2. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    the 7900gs is better basically. also not a lot more cost than a 7600gt
  3. morris8809
    30 Dec 2006
    more info
    the system i will be using it on has:
    Pentium D 925 3.0GHz
    1GB corsair 675 DDr2 dual channel
    gigabyte Ga-8N-SLI mobo
    80GB sata 2 hard drive from western digital
    and a 500 watt ps
  4. morris8809
    30 Dec 2006
    So martin which do u reccomend?
  5. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    The 7900GS is faster. :)
  6. morris8809
    30 Dec 2006
    u read my mind
    thx for the reply, ive read threads dat say the 7900Gs overclocks really good.
  7. morris8809
    30 Dec 2006
    is dat true?
    have you all heard the same?
  8. M4RTIN
    11 Sep 2006
    ive seen people get the 7900gs to the level of a GT with volt mods and better cooling. so its a fairly nice saving.
  9. morris8809
    30 Dec 2006
    thanks
    well i started out looking at the 7900gs and i really didnt kno if it was worth it to spend 40 bucks more for it over the 7600GT, im going to keep this system for a while and dont plan on upgrading to the 8800 and quad core for a long time. So i guess i may go with the 7900GS which brings me to another question, Which manufacture? i was mainly looking at BFG tech, EVGA, or XFX, please post any comments about these companies.
  10. Vergil_117
    Vergil_117 What's a Dremel?
    22 Jun 2006
    I would suggest eVGA, but BFG is also a great choice.
  11. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    If you can get the BFG 7600GT from newegg.com, $65 mail in rebate on a 145 dollar card, great deal!
  12. morris8809
    30 Dec 2006
    thanks
    Thanks, i was looking at xfx because their card has higher stock clock speeds for the same price, but bfg tech and evga also have good clock speeds so i guess i will go with who ever has the lowest price.
  13. mrbungle
    20 Sep 2004
    7900GS is a far superior card, also most get 600 on the core and then its real fast :)
  14. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The EVGA 7900GS-KO has a nice cooler on it, copper and covers the ram. The XFX one does not look to be copper, so it might not cool as well.
  15. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    check my sig. I have a 7900GS, the Gainward Golden sample.
    You can pick it up in either 256MB or 512MB form, and to answer your questions, here is a link to a review (ok its the 512MB version, but should show you just how much more powerful the 7900GS is over the 7600GT)
    http://theinquirer.net/default.aspx?article=34406
    Basically, here is how it goes...
    7600GT, 256MB DDR3 @ 700Mhz (typical)
    will overclock, but the memory interface is only 128bit, which means the memory bandwidth is around 22GBps. Thats not a bad figure, not in the slightest, but compare that to the 7900GS.
    7900GS, 256MB DDR3 @ 700Mhz (gainwards golden sample - stock is 660)
    256bit memory interface provides around 44GBps memory bandwidth. This is INSANE given that you can pick up a 7900GS for just £15 more than a 7600GT.
    As that Inquirer article says, the 7900GS does overclock like mad, i have mine running VERY stably at 654 core and 827 memory (thats 1.654 Ghz DDR3!!) and considering the default clocks for a 7900 are 450 core and 660 mem, that is some increidible overclock.
    The gainward cooler is a dual slot solution, so you'll need to bear that in mind, but it is far superior to the stock Nvidia reference cooler used by most board partners.
    Look out for the PALIT 7900GS, insiders tip - although it is clocked at default speeds of 450/660, this is in fact a gainward 7900GS minus the extra black metal covering, and WILL overclock the same as mine.
    Get it,and watch your frame rates soar compared to a 7600GT, which isnt a bad card, but the 7900GS is miles better.
