Graphics GeForce FX5200
Discussion in 'Hardware' started by dirtbiker, 16 Jan 2004.
  1. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Hi, i got the above GFX card with my Novatech machine and it seems to be running pretty hot. Im wondering if it should have a fan on the GPU cos at the moment it only has a heatsink? All help appreciated. :baby:
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Most FX5200s are passively cooled. Unless your experincing any problems with the card I'm sure it would be fine. So long as you've got decent airflow going through your case. Of course if your really worried you could just mount a fan on the hestsink.
  3. dirtbiker
    24 Dec 2003
    Thanks, thats what i was looking for. Airflow in my case isnt too bad, but i might put a fan on, just for safety... :rolleyes:
  4. calnen
    calnen moo!!
    2 Oct 2003
    I'm going to add one to my 5200 at some point.. it runs fine on standard, but starts getting hot pretty fast when you O/C with just a heatsink.
  5. ufk
    ufk Licenced Fool
    3 Jan 2004
    Only the fx5200 ultras come with a fan on the heatsink, and yes they get bloody hot bloody quickly when you overclock, got a little fan off a old 486 heatsink that looks like it'll fit a treat on mine just got to get the araldite out to make some screwmounts
