Graphics Geforce GTX 690! - Super sleek! and powerful (2x 680)
Discussion in 'Hardware' started by GoodBytes, 29 Apr 2012.
  1. GoodBytes
    20 Jan 2007
    Nvidia has announced the new Geforce GTX 690, which is 2x Geforce 680 put into 1 card.
    NVIDIA CEO Jen-Hsun Huang said "from the ground up to deliver the highest performance in history".
    Nvidia website says:
    - The exterior frame is made from trivalent chromium-plated aluminum, providing excellent strength and durability
    - A fan housing made from a thixomolded magnesium alloy, which offers excellent heat dissipation and vibration dampening
    - High-efficiency power delivery with less resistance, lower power and less heat generated using a 10-phase, heavy-duty power supply with a 10-layer, two-ounce copper printed circuit board
    - Efficient cooling using dual vapor chambers, a nickel-plated finstack and center-mounted axial fan with optimized fin pitch and air entry angles
    - Low-profile components and ducted baseplate channels for unobstructed airflow, minimizing turbulence and improving acoustic quality
    In total, the GTX 690 has 3,072 CUDA cores, running at a 915MHz base clock and 1,019MHz boost clock. These are slightly reduced from the GTX 680. If has a TDP of 300W. The memory clock is unchanged however and you get two batches of 2GB of GDDR5 RAM (4GB total, 2GB per GPU)
    It will be available in limited quantities starting May 3, 2012, with wider availability by May 7, 2012. Expected retail price is at $999.
    Source: http://pressroom.nvidia.com/easyir/...prid=880385&releasejsp=release_157&xhtml=true
    If you look at the SLI bridge, you can see it's no longer a ribbon, but a card. I wonder if this will come into play.
    [update]
    Card:
    Head over Anatech (http://www.anandtech.com/show/5795/...gtx-690-dual-gk104-flagship-launching-may-3rd) for more pictures and comparison table between the cards.
    [/update]
  2. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Great news! I'll be in the market for a high-end GPU in a few weeks :)
    Where did you find the clock speed info? It's not in the press release.
  3. GoodBytes
    20 Jan 2007
  4. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    Holy frigging shoot! a grand for 1 of those GPU? damn! that's too much money!
    Also I noticed your post count is almost there in the 9K range.. Congrats on that btw when you reach 9K
  5. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    That thing is a beast.
  6. GoodBytes
    20 Jan 2007
    @debs3759, I updated your avatar picture to a more modern OS.
    (yes I just did it for you) :D
  7. GoodBytes
    20 Jan 2007
    It can't be over 9000!
  8. Gaming_freak_10
    5 Jun 2010
    nice one there, dude! lol but still.. it'll be over 9000 soon..:worried::worried:
  9. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    I bet we'll be seeing a couple of Palit GTX 680 Jetstream 4Gbs on the marketplace soon :D
  10. Pookeyhead
    30 Jan 2004
    I hope that's not necessary. I like some control over what slots and how far apart my SLId cards are.
    You sure about that? If each GPU has 2GB then surely it's still a 2GB card. Essentially aren't they just 2x 680s in SLI like every other dual GPU NVidia card?... or is that what you meant?
    I'm not a massive fan of dual GPU cards. 2x 680s in SLI will easily beat this thing despite what they say on Anandtech. The only time I'd consider this is if I was going to get 2 of them... as 4x 680s would be problematic in terms of space, slots, heat build up, and power cabling.
  11. samkiller42
    25 Apr 2006
    Crikey, that's some monster, although how that fan is supposed to keep it cool i have no idea.
    Sam
  12. feathers
    feathers Minimodder
    11 Apr 2009
    300w TDP is very good when u consider a single 680 has a TDP of 195w. That means a total TDP of about 520 if you allow 220 for heavily overclocked cpu.
  13. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    If TG sells his 4gb's for one of these he is crazy! I dont think he is a fan of dual GPU cards. I tend to steer clear myself.
    Bennie
  14. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    It might be crazy and unworkable for gaming if sli doesn't like the game. Bur I'll say this; I love the look of that thing!
  15. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    damn a 1000$ for a card...
    I was kust thinking, the older cards like a 570 won't drop in price because of this right?
  16. feathers
    feathers Minimodder
    11 Apr 2009
    SLI works for most games and those that don't would run fine on a single GPU.
  17. rollo
    rollo Modder
    16 May 2008
    No they won't
    Does 1000 dollars transfer to 1000 pounds i wonder if so that is totally nuts not that I'd ever buy it
  18. KidMod-Southpaw
    28 Sep 2010
    It looks really slick, but it's still not going to be worth the money.
  19. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Thanks for sharing GB..
  20. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Looks like 2 x 680GTX 4GB is the way to go. Congrats nVidia on shooting yourself in the foot with a $1000 card. With only 2GB of vRAM per core- and with folks posting benchmarks with BF3 saturating 2GB of vRAM the 690 is an awfully expensive coaster.
