Hardware Gelid GX-7 Review
Discussion in 'Article Discussion' started by brumgrunt, 27 Jan 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Just wanted to say thanks for this review as I asked for it the other day.
    Now I'm going back to the beginning to read it properly.
  3. SchizoFrog
    5 May 2009
    OK. Here's my question. I was interested in this cooler as it caters for those of us who like to light up the insides of our cases and coolers with this feature or gimmick as you will have been few and far between. If I wanted to buy a different block cooler that used clip on fans, which would be the best 'light up' case fans to use with a CPU cooler?
  4. greigaitken
    greigaitken Minimodder
    26 Aug 2009
  5. SchizoFrog
    5 May 2009
    Seriously? Nothing new in 2 and a half years? And the advice from back then was basically not to use them unless you want very loud fans. That review was case fans being used as such. I am asking which if any case fans would be suitable with a CPU cooler. I also don't think the Sharkoon Silent Eagle 1000 would shift enough air to work well with a CPU cooler.
    So I am still none the wiser.
  6. Sarakon
    Sarakon The German
    11 Feb 2011
    Wll I'm using the CM Xtraflo. Despite being said its a loud fan; I don't think so, sure on high RPM most fans are loud, but it does not make any noise on low RPM and looks pretty and pushes lots of air!
  7. Alike
    Alike What's a Dremel?
    12 May 2009
    Why is there a difference in the design score for LGA1155 and Socket AM3+?
  8. Lance
    Lance Ender of discussions.
    6 May 2010
    I really like this pic...
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Stay away from any "fancy" looks fans, they all suck.
    Just stick to proper fans from reputable manufacturers like Pabst, Delta and so on.
    If you want light inside your Pc just use normal Leds separately from the Fans.
  10. Dedlite
    Dedlite What's a Dremel?
    4 Apr 2010
    No Thermatake Frio in the results? :(
  11. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    I don't understand why a "heatpipe count" would be particularly relevant to AMD processors only - that makes no sense at all.
    Surely the heatpipes are irrelevant - if the heat is getting to them then they will work or they will not work, the processor that the heat comes from would have no effect on that fact, surely? Or are you alluding to where the heat comes from on an AMD proccy or something? If so - then very poor show on Gelid's part as that should have very little effect on the dispersion of the heat if the block of copper on the bottom of the cooler was at all uniform.
    Or just to extrapolate a bit further, are you suggesting heatpipes simply work better on AMD proccy's because AMDs are hotter and thus the superconductor inside the heatpipes operate a bit better? Because if so - that should be quite explicitly stated - as it doesn't make it poor design on Gelid's POV, more good design by Intel.
  12. Tangster
    23 May 2009
    Phobya nano g and nano 2g's have decent static pressure and are red LED. I'd still prefer to light the case separately to the fans or drill holes in the frame and mount your own choice of LED's.
Tags: Add Tags
