Hardware Gelid Tranquillo CPU Cooler Review
Discussion in 'Article Discussion' started by Sifter3000, 20 Jan 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    David likes this.
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Titan Fenrir still the king of air
  3. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    What happened to the LGA775 results?
  4. woodss
    woodss Yes Louis Wu
    19 Jan 2010
    This thing looks like a mountainbiking shin pad or riot gear casing.
  5. cjmUK
    cjmUK Old git.
    9 Feb 2004
    I think I'd choose this over the Fenrir now... Silence is Golden.
  6. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
  7. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Can we get a review of how the Artic Cooling Freezer 7 Pro V2 stands up against this cooler and the Titan?
  8. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Nice price, i'd still pay extra for a Corsair H50-1 though as nothing touches it!
  9. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    You could have done a little extra with a more powerful fan or with the stock fan at full speed. I know it loses the point of a cooler being capable or not out-of-the-box but since you say that with a more powerful fan it could make Fenrir fear, it would be nice.
    If that was proven true, Gelid could really make that extreme one. Think of it as Top Gear reviewing the Koenigsegg, they said if the car had a wing, it could fare much better. Later on, Koenigsegg followed TG tip and the car worked even better than the original wingless
  10. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    Any comments on how tall this sucker is? Considering it for a HTPC build and wondering if it will fit into an ARK 400BA.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    Mentioned right at the start of page 1. 153mm high from base to the tips of the heatpipes.
  12. mycopia
    mycopia What's a Dremel?
    25 Nov 2009
    well if going up against the above why not vs akasa freedom tower too :) ?
  13. SchizoFrog
    5 May 2009
    The main reason for me wanting to know about the Freezer 7 Pro is because the original was so popular and that the V2 has extra socket compatibility. I would hazard a guess that the majority of people with Core2 CPUs are running the Freezer 7 Pro if they haven't already upgraded. The V2 also hits a great price point too if the performance is up to it.
  14. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    Yeeeessssss, but how tall is the entire heatsink, eg. will it fit within the confines of the case after being mounted to the CPU.
  15. Guest-16
    Guest-16 Guest
    Well, simply add 153mm to the height of your CPU socket from the motherboard - difference cases have different sized standoffs - and then deduct it from the distance to your case side panel (minus any fans on it).
  16. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    Wow, ok, I read the original response all wrong. Not sure WHY, but for some reason I read it as 1.153mm and thought "tips of the heat-pipes" was referring to the small heat-sink component on the copper base...don't ask why, but thank you for the clarification. I'll shut up now.
  17. MeanGreeny
    MeanGreeny MeanGreeny
    29 Aug 2009
    Would it be easy to fit a more powerful though quiet fan e.g. a gentle typhoon or maybe an S-Flex with a 3-4 pin adaptor to the MoBo PWM fan header ?.
  18. azrael-
    azrael- I'm special...
    18 May 2008
    The Titan Fenrir may be (one of) the best for air cooling. However, it weighs in at approx. 1.1Kg, which I find way too heavy for a cooler, no matter how it's mounted. Even the Tranquillo at 640g comes in a bit too much on the heavy side for my taste.
    For what it's worth, I'm mostly interested in the best air cooler weighing around 500g, preferably using top-down cooling and using a mounting solution with a backplate instead of those horrid (Intel) push pins. Never could figure out why they abandoned the mounting method introduced with the P4.
  19. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    Looks like this is my choice over the Fenner. A few quid cheaper, only a few degrees warmer, quieter. sold.
  20. Jevon
    Jevon What's a Dremel?
    28 Apr 2009
    Quick question - I want to overclock the Intel G6950 on a LGA1156 chipset m/b. Will this cooler be up to the job, or do I have to go to the Fenrir?
    AdvTHANKSance,
    Jevon
Tags: Add Tags
