Well I built my pc everything works perfect and fine I have a LGA 1566 socket and the heatsink came with only 3! thread screws that connect the heatsink to the motherboard. This meant I was unable to put in the 4 screw because it wasn't actually a screw! So it is running fine at the moment, but I really need another screw, I have emailed Gelid solutions about this, they have not replied as of yet. I am just wondering if there is any place to find the these screws on the internet to buy. As they must be worth very little. This is very annoying but a good heatsink. At the moment the i5 750 idles around 30degrees, probably due to the not properly fitted heatsink as of yet. Just a quick edit, when i said connects to the motherboard I meant the mounting bracket behind the motherboard. Any ideas would be great Thank you
Hi, I also have a Tranquillo but I use an AMD CPU so don't need the screws (I presume you are talking about the largish ones with the tension springs) so if you P/M me with your name and address I will send you one.
It will be posted tomorrow (wednesday) so should be with you thursday. Let me know if you receive it ok.
Yep, I had the same with my Titan Fenrir. Was looking for LGA775 parts, and this forum stepped up. All hail Bit-Tech!
Alot of people have adviced me from buying the components and building my new PC. Bit-Tech Forum members are fantastic, and to join this forum where I can learn this info has been one of the best decisions I have made Bit-Tech is a fantastic forum!
