Linux Gentoo Linux?
Discussion in 'Software' started by Mante, 20 Dec 2005.
  1. Mante
    Mante What's a Dremel?
    13 Dec 2005
    Hi everybody !! This is my first post and i am from Argentina so i don't speak so well english(i speak spanish :p).... Can any of you guys tell how is this version of linux (gentoo).... because i was reading and looks coll but i don't have any idea how it works
    Thanks for understand me
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I use it. so does Goat, and a few other on here.
    Honestly i love it i can't give one specific resaion why i like it but if i had to i'd say Portage and Emerge
  3. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    The one thing I do'nt like about gentoo is that you have to compile everything before you use it. It makes it run Way fast, but it's extremely time consuming.
  4. pat1
    pat1 What's a Dremel?
    13 Jul 2004
    I have tried many many distros, but my favorite is definintely gentoo. Portage is great...
    Also, they have such a great community on their forums. If you ever have a problem, you can find the answer there
  5. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    you dont have to compile everything first, you can do a stage 3 install then install stuff from binaries if you like
    kinda defeats the object of gentoo though..
  6. Mante
    13 Dec 2005
    Thanks guy i'll try it an then i tell you what i think !
  7. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Just for clarification, installing from stage 1 or 2 has no advantage over stage 3 for normal installations.
  8. tk421
    tk421 Idiot.
    15 Jan 2002
    i installed from a stage3, and got up to the install bootloader/first reboot step.
    no network connection, and my lilo prompt delay was .15 seconds instead of 15 ...
    it can be frustrating ... but for some reason i cant get a distro with a graphical installer to work on my system. tried opensuse, 3 different mandrakes, both from cd and dvd .. i'm guessing it's the shiny new x850pro in there ...
  9. HapeMask
    HapeMask What's a Dremel?
    19 Jan 2006
    I've been using gentoo for about a year, and I'd say the nicest thing is portage. Yes it compiles from source by default, but that is the point of gentoo in the first place, and I love being able to just pick a package I need and emerge it without worrying about dependencies. Especially for running Blender (3d software) I notice a definite rendering speedup between rendering the same file on windows and gentoo. If you don't like using a cmd line however, I'd suggest you skip gentoo.
  10. BobCobb
    BobCobb What's a Dremel?
    4 Apr 2006
    Gentoo has treated me well. And the command line is your friend.
  11. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I used Gentoo for a few times (installed about 6 times). Once you get around the slightly more complex nature, it's really a great linux distro. Emerge is just fantastic.
    I recommend you know linux at least a little before trying, I've screwed up my system many a time (even after I knew gentoo).
    It is fast though, and thread management is brilliant, I had no trouble compiling (using both cores), chatting via IM and browsing all at the same time.
  12. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    I am using gentoo since september.
    Before, i had to use windows because always somethings were not working. Now i am going to delete windows, because in gentoo i add to configure everyting manually, everything work. Definitivly, gentoo is the best distro for my computer
