Linux gentoo trials
Discussion in 'Software' started by Woodstock, 10 Sep 2007.
  1. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    after mucking around trying to ping bit-tech (modem cant auto detect dns servers(still couldnt)), i decide ill try to partition the 160gb ATA drive, but was quick to discover that fdisk couldn't open /dev/hda, so i ponder and end up poping in a Ubuntu live cd to see what it thinks of the drive, fdisk couldn't open it so i think to myself ill try gparted hopefully that will give a meaning full error to find to labeled as sda, grrrr.... Now to start again
  2. Glider
    Glider /dev/null
    2 Aug 2005
    try
    Code:
    cfdisk /dev/hda
    But are you sure your HD is primary master? What does the install CD detect upon boot?
  3. Woodstock
    10 Sep 2006
    im a lil confused about why but it went fine when using sda. could someone point me in the right direction about make.conf its got me a lil stumped. this is a amd 64 install on a duel core processor
    edit:
    is it possible to download packages and compile later, also is it possible to pause a complie and restart the machine, then start the compile a few hours later
  4. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Might I suggest man emerge? It is possible to download packages and not compile them, but the exact flag escapes me right now.
  5. Guerrilla
    Guerrilla What's a Dremel?
    8 Oct 2006
    IIRC /dev/sda is a SATA hard drive, while /dev/hda is typically an IDE device (I think). So if you have SATA drives, they wouldn't be linked to /dev/hda.
  6. Woodstock
    10 Sep 2006
    it is not a sata drive thou lol
  7. Glider
    Glider /dev/null
    2 Aug 2005
    emerge -f <package>
    -f from fetch ;)
  8. Woodstock
    10 Sep 2006
    okay and what command to compile later
  9. Glider
    Glider /dev/null
    2 Aug 2005
    Portage doesn't do that by default, however Ccache does enable it (without any extra commands, just configure ccache). But tbh, I had limited results with it (and now I don't use it, I just let long emerges do their thing during the night).
    Gentoo Wiki guide
  10. Fophillips
    9 Oct 2006
    With newer kernels all hard drives are labelled as "sd*" depending on kernel config. My IDE drive is /dev/sda and my SATA /dev/sdb, try ls /dev to see what's in there.
