German-Project: CaseCon 'Force Cube'
Discussion in 'Project Logs' started by Capture, 7 Nov 2003.
  1. Capture
    Capture What's a Dremel?
    7 Nov 2003
    hmmm....send me technicle informations about your parts, if it possible to produce your parts.
    marcelb@gmx.de
  2. Capture
    7 Nov 2003
    ****....the plexi cap ist broken. do you see it ?
    i dont know the color for the chrome nut. what is better ? the blue,black, chrome ?
  3. Lord Kordir
    Lord Kordir What's a Dremel?
    5 Nov 2003
    Chrome I think
  4. Goldberg
    Goldberg What's a Dremel?
    27 Aug 2003
    Looking good :thumb:
    I like those HDD watercoolers ans reservoirs. Keep up the goodwork!!
  5. mence
    mence What's a Dremel?
    27 Nov 2002
    Capture, awesome work so far - I love the HD waterblocks very cool. What the guys are saying about the coolant is right - it'll just get hotter and hotter without anywhere for the heat to go! Have a look at Ibkikn's PC - he uses a Peltier passively cooled by a large heatsink to cool his coolant.
  6. Sid
    Sid Banned
    13 Mar 2002
    Looking good. It's a bit unfortunate that the drives were a bit long and went past that hole in the plexi motherboard tray. Otherwise you would have been able to feed any cables through much easier.
    http://www.zupperware.de/case/schub09.jgp
    How did you make the black back panel with all the PCI cutouts etc. It has a depth to it with various levels of cuts. Was that all milled from a single sheet of metal? :eeek:
  7. Capture
    7 Nov 2003
    ... more pics ...
  8. lepre
    lepre Minimodder
    28 Aug 2003
    8 leds :D
    keep going :rock:
  9. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    Some pretty nice engineering (read German) there bro…Did you run any proformance test on the design of your rez/cooling towers? That’s sure a lot of work on a design application if you did not test it. It does look shweet though… :thumb: :thumb:
  10. Fyberwire
    Fyberwire What's a Dremel?
    14 Sep 2003
    wow. Amazing. This entire case is very origional. Great work.
    The caps on the reservoirs dont look like the things inside a rotary engine.
    the picture is just a model but they look very similar... :eyebrow:
  11. Bluebark
    1 Sep 2003
    Wow...a wankle (sp)!!
  12. Capture
    7 Nov 2003
    The black panel is a single sheet of plastic (PE). i have googled some informations about Motherboards/case-measurement...
    look at formfactors.org
    or i dont understand you ?
  13. lepre
    lepre Minimodder
    28 Aug 2003
    you made up the reservoirs or you just bought a kit to do them?
    i'm searching for plexi like that...but can't find :(
  14. Capture
    7 Nov 2003
    i bought the plexi at ebay...
  15. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    my god, that rocks ! :rock: nice ! :D
  16. Pistol
    Pistol Guest
    Capture, your english is superb, don't worry about it. If a Texan can understand it, I reckon anyone can. I like everything about this case.
    Recommendations:
    Vinyl dye the CD ROMS.
    Smoke the acrylic on which your motherboard resides(just my opinion, I don't know where you're going with this)
    Use a heatercore...even a small one...
    ...unless you have a secret weapon?
  17. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Hey Capture, nice to see another guy working with all plexy cube!!! It looks like half of my plexy case (the leftmost section)....
    Very good!
    :clap: :clap: :clap:
