Scratch Build – In Progress GET A LIFE - COMPLETED
Discussion in 'Project Logs' started by The_Gnu, 17 Nov 2010.
  1. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Thanks.
    Hehe yeah kind of.. just not quite as easy to join though :)
    Yeah pretty much like that, All those heatsinks (+ 17 more :)) will be joined into one massive heatsink that will make out half of the case.
    Hehe tanks. Yeah I guess you could actually say that the finished case will have some tetris influenses.
  2. Baekkel
    Baekkel Picky Picture Villian
    17 Jan 2010
    This looks very promising, definately a build i'll be keeping an eye on!
    And the Zotac, It's a solid board.
    I've got one running 24/7 as file, printer and Minecraft server.. and besides the massive req's of the MC server. i've never had any issues what so ever.
    And with 4Gigs ram, it does 1080p movies like a charm.
    ( btw, go bios and ramp up that FSB, it goes 2Ghz without breaking a swet!! )
  3. The_Gnu
    12 Sep 2005
    Thanks. Nice to hear som feedback from someone who tested it. 4GB you say..then I'll have to test my set up with 1080p too see if I'll need to change my 2x1GB sticks. I guess it depends on what OS your running. I was thinking of running XP with XBMC but I'm also starting to like linux. What OS are your running on yours? Playing with the FPS is definately something I will do.
  4. Baekkel
    17 Jan 2010
    I was running Win7 Home ed.
    Just recently switched for Ubuntu, but lack of patience and skill forced me back to se7en again.
    With only 2gigs it stuttered mildly at 1080p, but managed 720p MKV fairly good.
    The FSB only goes at max 667.7Mhz, but stock cooler and the supplied fan in a restrictive case, only heats it @ 62-65 degrees Celsius under fair load.
    Haven't pushed it too hard yet, or monitored it under 1080p yet (been too busy watching what was going on at the screen )
    Classic Media Player - HomeCinema edition, supports the Nvidia ION hardware accelleration,
    Guess that's what makes it possible...
    Haven't tried Win XP on it, but my Netbook ran alot faster on Win7 than XP.. Dunno if it was due the better support for ATOM and ION, or it was my imagination..
  5. The_Gnu
    12 Sep 2005
    @ Baekkel
    Thanks for the info, I guess I will do some test and see how it all works when it's all put together. God point about atom/ ION support issues, hadn't thought about that but will definetly do some research.
  6. The_Gnu
    12 Sep 2005
    Got some stuff delivered today. A GPU cooler (Titan twin turbo) that will act my heatpipe donor and some extension cables and angle connectors. Since the Mboard will be mounted vertically and close to the bottom of the case, I need to move the connectors from the backside, and therefore use the angled connectors.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    I though it would be easy to just slide those fins of but it took around 2 hours since they were so tight and I had to cut them in 4 pieces each. And those *******s were razor sharp as well, fingers are pretty sore by now. I was also hoping that the heatpipes would only be attatched with some thermal grease to the base it seams to be some kind of thermal glue. Atleast it doesn't look like solder. I will have to figure out a way to remove them, I was thinking of bending the copper plate "backwards" to make the holes wider and hopefully losen the joint.
    Anyone done something similar or can think of a über method to loosen them?
  7. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    If I'm correct you can buy heat pips. (german shop)
    and this has way more pipes
    Zalman ZM-2HC2 HDD Cooler
    wolfie
  8. razerz
    razerz What's a Dremel?
    2 Aug 2009
    Available from Conrad in Sweden too
    Regarding loosening the heatpipes you have now, your idea is probably the best bet.
    I would try to place one side in a vice and using a hammer to bend the backplate. And after that using a hammer and chisel to get between the heatpipe and copper base.
  9. The_Gnu
    12 Sep 2005
    Thanks for the links. I have actually already looked at both of those alternatives. The reason why I didn't buy single ones from conrad was beacause when I was looking at the swedish site I couldn't find any specifikations to be shure of the performance. But I see now that your link to the german version has some PDF info about them. Never thought of that :)
    Unfortunately the pipes in that zalman cooler is a bit to short.
    Thanks for the tips, will keep that in mind, I'll have to be carefull to not damaging the heapipes with the chisel thoug.
  10. asura
    asura jack of all trades
    22 Apr 2009
  11. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    I've read that some types of thermal glue become fairly brittle at cold temperatures. You could try throwing it in the freezer for a few hours and then try wiggling the heat pipes around a little.
  12. jrs77
    jrs77 Modder
    17 Feb 2006
    You could try solvent to get rid of the glue, like aceton or ethyl acetate.
  13. The_Gnu
    12 Sep 2005
    thx for the link, didn't know they sell extensions for those HFX cases.
    Thx for the tips guys, will try some acetone straight away and put it in the freezer over night if the solvent doesn't do any good.
  14. bulldogjeff
    2 Mar 2010
    Wow that grill is seriously sweet and I don't envy you playing with the fins,I've cut myself just fitting a cooler.
  15. The_Gnu
    12 Sep 2005
    Hehe yeah my fingers are starting to heal now :)
    Continued my work with removing the heatpipes today. Since I was sure they were glued I tried with the acetone and freezer tips but non of them worked. So I went to the workshop and tried to bend the flat piece in the vice to widen the mounting holes and losen the glue. Here is the pic of that process.
    (CLICK TO ZOOM)
    This method turend out to be FAIL. When bending the piece I realised that as the holes got wider, the pipes got wider aswell. They were sticking so hard to the walls of the hole that they started to deform. A friend took a look at it and toold me it was mos likely solder and gave me the tip of putting it on the stove untill the solder melted. So... I put it on the stove. I had read about this technique before but was a bit worried about the heatpipes exploading or cracking since I've heard that 100ºC is their limit (sounds a bit low though). But thinking about it a second time, since the pipes are soldered, the melting temp of the solder have to be lower than the maximum heatpipe temp. But just in case, I put on some safety glasses, turned on the stove and in a minute or two, the pipes dropped down one by one as the solder melted. Quickly pulled them away from the stove once loose and let them cool. There was some smoke before they melt that got me worried but I guess it was only some grease or something, because I tested them after and they all work fine.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    Away with the stock heatsink since I need to take some measurements for the new heatpipe cooler.
    (CLICK TO ZOOM)
    Here is the reaelly thick piece of thermal pad used on the CPU. This is because the GPU and CPU have adifferent heigth. I have to thank Sanatarium here on the forum for providing the exact heightdifferent in his worklog.
    (CLICK TO ZOOM)
    Here I'm testfitting the heatpipes. This is how it all will be mounted. Heatpipes will be connected, behind the mobo, to the large 5mm thick aluminium plate that is also the base of the heatsink.
    (CLICK TO ZOOM)
    And ofcourse I also did some more heatsink parts, since the process is the same as the other parts, I wont bore you with the almost exact same pics.
    (CLICK TO ZOOM)
    All part so far put together.
    (CLICK TO ZOOM)
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    omg I never thought of being able to scavenge heatpipes! hmm plan on. Great work so far dude!
  17. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    lol, thought your last pic was a metal periodic table of the elements... :duh:
  18. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Looking good. I love the idea!
  19. The_Gnu
    12 Sep 2005
    Thanks. I actually like scavenging more than buying new, it's something about that "look, I turned this into THIS, muahahaha" feeling.
    hahaha.. well that would have been a little too geeky, even for mee :)
  20. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    Love the space invaders heatsinks! :clap:
