Scratch Build – In Progress GET A LIFE - COMPLETED
Discussion in 'Project Logs' started by The_Gnu, 17 Nov 2010.
  1. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Dooooooooooood!
  2. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Wow, looking at that last picture, it seems a shame to cover it all up! Maybe you have a few spare days to file 3mm square holes in a perspex back panel ;-)
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking good. :clap:
    This picture deserved a bump onto the next page. :D
  4. David
    7 Apr 2009
    Simply staggering attention to detail.
    Gawd, I love this build.
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I'm amazed! But she must be a good woman! :)
    Beautiful update m8! :thumb:
  6. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Nice work on the on the sata power cables they look very professional, wont all that metal block alot of the wifi signal? or is that why you used a large antenna.
  7. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Thanks mate:thumb:
    Yeah I have thought of that also. But the main plan B is to putt the antenna inside a "handle" I've maid in the backpanel. It's made of plastic and should be good enough to let the wifi signal pass through. Kind of like the plastic apple loggo on the ipad that also acts like an antenna.
    Btw, I just realized I havn't showed you guys the backpanel after anodizing or the completed front either. Time to sort out som pics I think.
    Thanks you guys, apreciate your support, you:rock: :)
    You bastar, thats actually a good Idea and would be kind of cool, Im thinking smoked black plexi thats only transparent when there is some faint light on the inside. But I think Ill skip that for now and use the one I got. Don't tempt me like that:thumb:
    Haha, thanks for the bump mate.
    Thanks Spreadie, Then I hope you will like the end aswell:naughty:
    So am I, but I got some hosehold duties to catch up on once this is done though :S
    Thanks:thumb:
    Thanks buddy. Yes I am a bit worried that all the metall will block it. But since all holes over 5mm will not block the signal, Ihave hopes that some of it will get through in the bottom of the case. But this method is just a test and I got a backup solution incase this will not work. Btw the antenna is the normal size one that came with the case.
  8. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    Now that I've got up off the floor I can comment .... this just keeps getting better and better :)
    I wouldn't worry about the antenna getting a signal I think the shear awesomeness of the case will attract the wifi :jawdrop:
  9. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    I am amazed with the compact and efficient design. :thumb: Great execution.
    I can't wait for the wrap-up.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe: Cool comment & bet it's true. :D
  11. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Wow is this coming out nicely. Sweet... :clap:
  12. KidMod-Southpaw
    28 Sep 2010
    ABSOLUTELY incredible! I just can't believe the attention to detail put in here! Great work- well done! :thumb:
  13. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    too much awesomeness for such a small pc :thumb:
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    A beauty!!! Can´t wait for final... Btw, how small is the thing?
  15. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Beautiful art, and we still have not seen the panels :jawdrop: :jawdrop:
  16. matiss
    matiss Minimodder
    24 Jun 2010
    Absolutly wonderfull brilliant.
  17. The_Gnu
    12 Sep 2005
    Haha I don't know If I have managed to give it that Cuck Norris ability but I sertinly hope I'll atract some wifi. Will fire it up tonight and test it.
    Thanks daniel. Yeah I have to admit it is actually a bit too compact. Im really struggling now when I try to fit the cables.
    Totally agree LMAO.
    Greate words from a greate builder himself.:thumb:
    Thanks KS. Awsome and supportive as always:rock:
    Thanks, I think I've got a thing for small PCs now. Would be nice to have an even smaller Rasberry PI version of it:naughty:
    Thanks mate, the final is pretty close now:naughty: The size is around 24x24x6,5cm (two coke cans high/wide), not shure about the weight yet but I'll weigh it once its done.
    :naughty::naughty::naughty:
    Thank you for your support matiss:thumb:
  18. bugeye
    16 Aug 2011
    Chuck Norris is happy with your work .
  19. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Just nice work but are us sure the wifi is going 2 work ??? as i can see not more then few meters.
  20. weatherdown
    weatherdown What's this button fo......
    27 Dec 2011
    Before I even scrolled down far enough to read this comment I read the "this computer will attract the wifi" comment and immediatly thought of Chuck Norris :D
    @The_Gnu: Good work. can't wait to see it finished! :thumb::thumb:
