Cooling GETO EXOS - A good external ~$200 setup
Discussion in 'Hardware' started by Altron, 22 Jan 2004.
  1. Altron
    Altron Minimodder
    12 Dec 2002
    Here is what you will need for the GETO EXOS.
    I read a lot about watercooling and picked what I tohught were the most reasonably priced components, I will make a list of them, hopefully this can eb helpful to behinners. The said setup is CPU only but can easily be modified to add in a GPU waterblock.
    CPU Block - DD RBX $53
    http://www.dangerden.com/mall/Blocks/rbx.asp
    Radiator - D-Tek Cooler Core $32
    http://www.dtekcustoms.com/product.asp?0=205&1=226&3=91
    Pump - Danner MagDrive 5 $50
    http://www.reefgeek.com/products/categories/pumps/103756.html
    Tubing - 1/2" ID Heater Hose ~ 10' (between $10 and $15)
    Check your local car store
    Clamps - Adjustable steel clamps, quantity 10, around $1 each
    Check your local hardware store
    Resivior - 16" x 8" x 6" plastic bin, should be around $5
    Check your local Walmart-esque store.
    120mm fan - $5 or so
    Check the modding shop of your choice
    What you do is attach the waterblock. Run the tubes out of an extra hole in the back of your case.
    On the lid of the bin mount the radiator and pump. Cut 2 holes in the lid and put a bit of hose in them. I reccomend going resivior > pump > waterblock > radiator and then out the radiator into the bin.
    Fill the bin up with distilled water and any additives you want.
    Whilst it's not as sexy as the EXOS it's got far more performance and flexibility.
  2. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    * +Altron doesnt pay taxes
    Now that is geto. Lets see some pictures of it once you build it. :thumb:
  3. Altron
    Altron Minimodder
    12 Dec 2002
    Accepting donations for building it :)
  4. woodshop
    woodshop UnSeenly
    14 Oct 2003
    build it build it build it <edit> would it work with an old sink some silicone and a 2x4?</edit>
  5. Altron
    Altron Minimodder
    12 Dec 2002
    Anything that holds water works, although I reccomend you DO NOT use your bathtub for it. We like to promote hygene :p
