Other Getting BT to lay fibre to my house
Discussion in 'Hardware' started by forum_user, 14 Nov 2013.
  1. forum_user
    forum_user forum_title
    4 Jan 2012
    At my new house there is a mix of copper and fibre to the cabinet. The nearest exchange is 2 miles away and the broadband speed is bad.
    How would I go about asking BT to lay a pure fibre line to the small group of houses (8 homes)? I vaguely remember someone did this before. I think they had to pay but I'm not overly bothered about that - I am bothered that I am going from 5.5Mb to 1.5Mb!!
    So, how do I get to speak to an organ grinder as it were, rather than call centre staff who will likely tell me I cant do it.
  2. Teelzebub
    27 Nov 2009
    You probably need to speak to BT wholesale but good luck with that they don't normally speak to private users
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    What's your post code?
  4. ccxo
    ccxo On top of a hill
    23 Oct 2009
    What does the BT wholesale checker say about your line- (use telephone number or address), as you mention FTTC so what speed offering is that, the checker will give a estimate if its avalaible.
    https://www.btwholesale.com/pages/s...unity/Coverage/ADSL_Availibility_Checker.html
    Openreach offer Fiber on demand (FOD) this is currently being extended across their FTTC network and if you line is connected to a enabled FTTC cabinet then you can order a full FTTP line to your property.
    3G/4G may offer better speeds and its worth seeing if their are any wireless providers in your area if FTTC is unavailable.
    Link to BT Buisness leased line service.
    http://business.bt.com/broadband-and-internet/leased-lines/
  5. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Hope you have deep pockets, used to quote for fibre lines for BT Business many years ago.
    You will be looking at 10's of thousands for the contract even if you just for a 10/10Mb line and you would have to organise splitting it and sharing it yourself between the houses, essentially becoming your own mini ISP.
    Try looking into EFM quotes for your postcode, just Google and see a few companies to get a rough idea of what getting Ethernet laid would cost.
  6. rollo
    rollo Modder
    16 May 2008
    If your a millionare its a viable option otherwise you should look at 3g or 4g instead. 2 miles away from exchange I assume you have no local cabinet, Means you need both so its more extra expense.
  7. Harlequin
    Harlequin Modder
    4 Jun 2004
    cant you get FTTC from BT (or sky or plusnet?)
  8. saspro
    saspro IT monkey
    23 Apr 2009
    2km of fibre would be around £25k of installation + probably £600 a month + VAT for 10/100
  9. Harlequin
    Harlequin Modder
    4 Jun 2004
  10. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    eeek it's really expensive if you live that far from the exchange.
    Look at a wimax connection, though, to split up the connection you will need to invest in a decent firewall, like a fortinet or a juniper (for example).
    if you got fibre running to your property, they would stick a big router in there and an nte and you would still need to get a big firewall. 10mb on a 100 bearer is going to also be expensive.
    I think a wimax connection would be superior to an efm circuit, and might be less in installation. though I guess that depends on the wimax provider, as I'm fairly sure efm is always synchronous, where as wimax might not be (might be point to point).
  11. kenco_uk
    28 Nov 2003
    If you have FTTC, PlusNet offer 80/20 for £19.99/month. And it is superb.
  12. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    i suspect the issue might be the cabinet is too far away to provide 80/20, or indeed better broadband than is already available over the presumably copper wiring from the exchange or remote cab to the home?
  13. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    So I moved in to a new build two years ago which had no phoneline installed (unknown to me at the time!).
    I checked the postcode on BT's site that said it was available so I ordered BT Fibre (not knowing the line wasn't installed at this point). So they came out, couldn't do the installation because the line needed to be installed - they went ahead and booked it all in and 6 months later the work was done (they had to lay some new cable from the cabinet I think - had to big up park of our drive as well).
    If the website says you can have it based on your postcode then order it, just be ready for a long slog to actually get the line laid.
