Linux Getting grub out the boot sector
Discussion in 'Software' started by steveo_mcg, 13 Oct 2007.
  1. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    In the past i've attempted dual booting on my gaming rig and usually given up for a number of reasons and gone back to the hardware of my nice quiet machine since i have got every thing working on that. However i'm going to give dual booting another go since i need to reinstall xp again any way, but heres the question how do you get grub out of the boot sector. In the past i've always resorted to zero filling the disk since everything thing i've tried has ended up with windows unable to boot after the cd stage since the NTldr doesn't seem to be in the boot sector. I've a lot more experience with this stuff now that i did last time i tried this but i'm still a bit nervous of have to shift all my files across the network to format the disk just so i can get windows to boot.
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Wipe the Linux partition(s), then boot with the XP cd in. Go into the recovery console, fix the boot record, then fix the Master boot record. (They're both simple commands, I don't remember which ones, though. It's fairly self-explanatory.) Reboot, eject the CD, and it should boot into Windows.
    That's the way I did it, anyways. YRMV, don't forget to back your important stuff up.
  3. steveo_mcg
    26 May 2005
  4. unicorn13
    unicorn13 What's a Dremel?
    26 Feb 2007
    Used many a time :)
    FIXMBR then FIXBOOT to get rid of Grub or Lilo (If in the MBR).
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    NM.
  6. dhm
    dhm What's a Dremel?
    13 Oct 2007
  7. steveo_mcg
    26 May 2005
    Thats what i used to do but it never seemed to have much effect.
