Motors getting petrol out of corsa
Discussion in 'General' started by anne7, 24 Aug 2006.
  1. anne7
    anne7 What's a Dremel?
    19 Aug 2006
    can anyone help, daughter had accident in her 1994 corsa 1.2 and we are going to have to scrap the car ( she not hurt) but she had just put £25 petrol in tank is there a way of getting it out without damaging the tank :wallbash:
  2. specofdust
    specofdust Banned
    26 Feb 2005
    Umm, you could stick a hosepipe in there and suck till the petrol comes, I'd use a clear hosepipe so you can see when its about through and not get a mouthfull of petrol. That's the only way I know of. Probably not terribly smart. Personally, I'd just let the petrol go, seems simplest, and least dangerous.
  3. kenco_uk
    28 Nov 2003
    Dump £25 of petrol?! Madness! :D
    Do the hosepipe thing and get two or three jerry cans. Take some extra strong mints, too! Garlic breath's bad enough, but petrol breath.. :)
  4. anne7
    19 Aug 2006
    we have tried the hose pipe thing lol but petrol wont come out. ur right bout the petrol breath though
  5. specofdust
    specofdust Banned
    26 Feb 2005
    Well if that doesn't work, the only thing I can think of is removing the petrol tank. But seriously, it'd take hours, you might as well just spend the time working and make the same ammount of money or more.
  6. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Yeah, most cars have an anti-siphon trap nowadays.
    When you're scrapping it see if you can get a bit extra because of the fuel that's in it.
  7. airchie
    airchie What's a Dremel?
    22 Mar 2005
    You could try puncturing the tank and draining the fuel but I'd be far too worried about igniting it if I did.
    Certainly not worth risking for £25 of fuel...
  8. BjD
    BjD What's a Dremel?
    10 Apr 2003
    Find the outlet pipe from the tank, position can underneath, and either cut the pipe or disconnect from the tank. May not work if its of the pump-in-tank arrangement.
    Or remove the tank and tip it upside down. If you're scrapping it anyway you can cut some corners (literally) which may make it easier to get out.
    The scrapman will most likely drain the tank anyway, may as well have go yourself :)
  9. cderalow
    cderalow bondage master!
    23 Jan 2002
    more annoyingly some scrap yards won't take it with a full tank anyway
    find yourself a nice sized metal bit and drill a hole slightly above the bottom on one of the sides (above bottom so you don't get any sludge from the tank)
  10. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Cut the fuel line, run it to a jerry can and turn the ignition on, all corsas should have electrical fuel pumps but I can't remember if they're in tank or not.
  11. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Your best bet is probably to cut through the fuel line. Don't drill into the tank - you run the risk of igniting the petrol then...
  12. mushky
    mushky gimme snails
    24 Mar 2003
    This does not sound good. It really doesn't sound worth it for £20 worth of petrol (you won't get it all out)
  13. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    Just pull the fuel pipe out of the injector rail ...... stick it into a length of hose pipe into your cran ..... then just keep turning the ignition on and off this will pump the fuel out.
    I had to do this on an escort we scrapped ..... except it had a FULL tank...... took a while but was worth it.
  14. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Mortus is right, did this with £40 petrol from a 620 that dropped a valve on the motorway, disconnect the starter though as it will get very hot when you are cranking it continuously...
  15. Freedom
    Freedom Minimodder
    27 Oct 2004
    chech the heynes or however you spell it manual there be summet in there usally telling you how to do it,
  16. webbyman
    webbyman Hax.
    7 Oct 2004
    I'd go with this idea, but if you don't know how to do it, sucking it up through a hose pipe isn't that baad. :baby:
  17. cderalow
    23 Jan 2002
    could also find the fuel pump power lines and just hook 12v dc to it... should kick the pump on and let it go
  18. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    All for the sake of £25?
  19. vacheron
    vacheron What's a Dremel?
    12 Feb 2003
    Don't know about the Corsa, but my car has a sump plug on the petrol tank.
    If you're lucky, just stick a bowl underneath it, undo the bolt, et voila! :)
