Modding Getting power to a desktop LCD (n00b question)
Discussion in 'Modding' started by Stu, 8 May 2002.
  1. Stu
    Stu What's a Dremel?
    8 May 2002
    If I was to order the NK204, the serial cable and the 12V wide voltage power lead, how would I go about powering the unit if it was like 3ft away from the molex on the power supply.
    The serial cable would be long enough, am I right in thinking its just a matter of snipping the wire and extending it ?
    Ta, again :lol:
  2. Stu
    8 May 2002
    Only need a quick answer :D :D :D ...come on guys, I wanna order meh LCD :dude:
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    get some wire, and then cut the power supply wire wires and solder in the new longer bits.
  4. Henry
    Henry Matrix Orbital
    13 Jul 2001
    get your self a external power adapter and cut the end off and solder the molex header onto it... that's the easiest option.. I have one more but harder :)
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    my idea is more fun. :lol:
  6. Stu
    8 May 2002
    Can you tell me more about these power adaptors please Henry, dont really understand what you mean:(
  7. WhyPush
    WhyPush What's a Dremel?
    22 Apr 2002
    Could use the power from the serial
    If you don't mind a little solder, you could follow the manual and make the unit accept power from the serial cable. Then you'd only have one cable.
    Not how I'm doing it with my new "all-in-one" external cable project, but possibility.
    I hope to have the cable done by the weekend and will post info when I do.
  8. Henry
    13 Jul 2001
    I was thinking of a regular DC adapter, like you would see to charge a cell phone, or a diskman power adapter, we use those here... jsut cut the end off, and solder on a connector
  9. linear
    linear Minimodder
    5 Oct 2001
  10. quack
    quack Minimodder
    6 Mar 2002
    I did mine the Macro way... all-in-all it's a sweet mod :)
    I know it's not terribly original but I did mine almost completely the same way (except I used 2x12v and 2x5v); but hey it works and is nice and neat.
    edit: linear: how many times a week do you change your avatar? lol, I've lost count of all the different ones!!
  11. Stu
    8 May 2002
    Hehe, cool, think I will be doing it this way :)
  12. Iamgoodyy
    Iamgoodyy What's a Dremel?
    11 Nov 2001
    On my VFD power line I just used ethernet, got a femal jack and hot glued it to an old ethernet faceplate, then crimped the cable to the right stuff.
    Iamgoodyy
  13. Stu
    8 May 2002
    Care to expand a little mate ?
    Maybe some diagrams ?
    Cheers :)
  14. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    i did mine the macro/scoob way.. except I bolted everything onto the cover plate backwards, and soldered and heat shrinked before I realized this.. :cries: pictures on the site..
    -scoob8000
