Windows Getting rid of data forever
Discussion in 'Software' started by DragunovHUN, 4 Jun 2010.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    For the sake of this discussion let's assume that i have some data that i don't want anyone to ever be able to find.
    As far as i know a quick format doesn't actually erase the data, it just makes it so they can be written over so untill something takes the place of that data it stays there and is recoverable.
    Would a full format actually overwrite the data with all zeros? Or would i have to fill the hard drive with some other stuff to get rid of it?
    Would that take care of it or is there something else i should do in addition, other than physically destroy the drive?
  2. Teelzebub
    27 Nov 2009
    I've got a program for doing that i think its called data shredder it takes ages to do its work.
    If I can find it I send you a copy if you want one.
    I believe just formating dosen't remove it completely its still possible to retrieve it.
    DragunovHUN likes this.
  3. Krikkit
    21 Jan 2003
    UBCD has a couple of data shredding utilities iirc.
  4. memeroot
    memeroot aged and experianced
    31 Oct 2009
    go on - what is the data?
  5. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I normally use Eraser. The 35-pass erase method takes ages though!
  6. capnPedro
    11 Apr 2007
  7. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    you can get rid of your porn using Recuva
    http://www.piriform.com/recuva
    its an un-erase tool, but also allows u to secure delete.
  8. Andersen
    Andersen Brain for hire
    25 Nov 2002
    DBAN it.
    A few zero passes and pass or two of random data should be enough. Gutmann is for the paranoid.
  9. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Man needs a little G from time to time.
  10. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    i use a program called diskwipe which seems to do the job, on some of the really sensitive stuff i run 37 passes which basically writes random 0/1 over the whole disk 37 times.
    Assuming you want the whole disk erasing that is.
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Thanks guys, +rep to the lot of you.
  12. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    Is this purely hypothetical DragunovHUN?
  13. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I occasionally host patent or design information I don't want recovered. There's a legitimate use for it.
    Have a HDD I will be doing like this myself. It's showing signs of spindle issues, will destroy the data and send it in.
  14. themcman1
    themcman1 is now 110% win
    1 Jan 2008
    Thermite is how it's done.
  15. KayinBlack
    2 Jul 2004
    Yeah, but not everybody here has access to it.
    Me, however...
  16. nathanddave
    nathanddave What's a Dremel?
    18 Apr 2010
    Yh I have used dban on some of my hard drives it is an excellent programme, and makes sure that you cannot retrieve the information. That is if you wanted it removed completely. Dban only does the whole hard drive, well it might do partitions but you'll have to check that one.
  17. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    Other than the solutions already suggested store the data on an old el cheapo drive and use a hammer on the sucker when you're done with it. It's not irretrievable with the right kit but beyond the ability of >99% to get a single byte off it and it feels so satisfying! :D
  18. balatro2005
    balatro2005 Minimodder
    19 Sep 2009
    Have used dban myself when i have sold any hard drives on ebay. So far my bank accounts are still safe lol
  19. Akuman
    Akuman Waffles
    5 Jun 2010
    Dunno how hardcore you want to go with this but here's some handy info
    US Department of Defense on Wiping Drive Standard
    And if you want to physically destroy the drive (which is overkill I reckon), a nice big magnet to corrupt the data followed by a hammer would work well :thumb:
  20. scq
    scq What's a Dremel?
    4 Mar 2005
    Degauss it, take out the platters, grind them to dust with a disk sander, then blend the metal dust with magnesium powder and set it on fire. Once done, blend the ash with baby powder and send it in 16 separate envelopes to geographically distant locations with instructions that the person is to scatter it. If they are by a body of water, scatter it in, or if they are in the prairies or a desert, wait for a windy day.
    Of course, the electromagnetic pulses of your writes could have produced radiation that has been emitted into deep space and will forever continue their journey. The only real way, is to therefore destroy the universe or collapse spacetime or something. You'll need to seek someone else for that sort of help.
