Cooling GFX card fan dying a very loud death
Discussion in 'Tech Support' started by davey_wavey, 8 May 2013.
  1. davey_wavey
    davey_wavey New Member
    24 Nov 2010
    Hey guys,
    One of the three fans on my Gigabyte GeForce GTX 570 OC card has decided it's had enough and is dying a long and very loud death.
    I was wondering whether it was possible to simply buy a replacement and fit it myself? If so, what spec fan should I be looking for and where would I buy one?
    Also, do you think it would be safe for my card to place something in the fan to stop it spinning and making such an annoying noise?
    Thanks for any help you can offer
    David
  2. total zombie
    total zombie New Member
    2 Nov 2009
    the card may still be in warranty contact the suppler and see what they say, i wouldnt block the fan, stopping them spinning will generate heat and possibly start cooking its self, if the card is out of warranty let us know i have a few more ideas.
  3. megadriveguy
    megadriveguy Active Member
    19 May 2010
  4. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    This first! :thumb:
    If you do want to DIY then if it were me I'd apply some ultra fine machine oil to the fans bearings. Do a little research first but it's likely all you need to do is peel back the fans sticker to reveal the inner workings then apply machine oil. When I've fixed fans in the past it only required a very small amount to lubricate the assembly.
  5. davey_wavey
    24 Nov 2010
    Thanks a lot for the replies so far. I'll contact the supplier and check if it's under warranty first. Enjoy your day!
