Modding Ghetto Mod Testing Station!!!
Discussion in 'Modding' started by mc909, 18 Jul 2002.
  1. mc909
    mc909 What's a Dremel?
    18 Jul 2002
    Got a spare power supply? Ever take modding to the next level and wire up yr own gadgets and gear? Just curious if that fan works? You need the Ghetto Mod Testing Station!!!
    All you need are a spare PSU, a few L brackets, and some extra cut off plexi and you too can have yrself a Ghetto Mod Testing Station!!!
    In order to get the PSU to start, take a small piece of hard wire (I cut a section from a large safety pin) and bend it into a ] shaped jumper. With the PSU off (!!) and unplugged bridge pin 18 (green wire) to any of the pins with a black wire (ground). Of course, at this point, test it and make sure that it will start.
    After that, measure up yr plexi and build a little enclosure. Mine could be better, but I just used some cheap castoff plexi and Goop the hold the PSU in.
    The testing posts are 5v, 12v and gound and intended for bare wire connections, the molex connectors are pretty straightforward anf the four pin fan connection is extendable ( hangs out the side!)
    Just make sure that you allow for some air input through the enclosed end or you risk the chance of yr PSU overheating.
    And finally, a pic of the Ghetto Mod Testing Station in action, with ubuquitous bloo leds...
  2. dez
    dez What's a Dremel?
    16 Jul 2002
    do u really need the plexi?
  3. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Do you really need a mouse?
  4. mc909
    18 Jul 2002
    LOL not really....just holds the testing posts and molex connections, and makes the the whole thing a little safer when dealing with bare wire connections
  5. dez
    16 Jul 2002
    do you really need to breath? lol j/k :D
    bare wire connectors? i just see molex
  6. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    No Plexy, Lotsa juice, SMOOTH power, GHETTO AS HELL!!!
    My testing setup... It'll pulse 1000+amps of 12V, or 12 amps continuous...
  7. dez
    16 Jul 2002
    ghettto for sure. im really and idiot when it comes to wiring anything. like clueless. i can dremel/etch/do all that, anything that involes hand work, but then the wiring, im clueless. usually have to find someone on the net whose done it, and written a really good article on it.:sigh:
  8. mc909
    18 Jul 2002
    the black, green and red parts you see are screw post test connectors, wrap the bare wires there and screw them down...
    mdpflum, what the heck or those big bloo thangs? capacitors??
  9. mc909
    18 Jul 2002
    hehe, s'not that hard really, if you remember the two golden rules;
    1) unplug it while yr workin' on it...
    2) use a really long stick to turn it on in case it explodes
    always works fer me...:D
  10. dez
    16 Jul 2002
    lol, good plan. just basicly anything, like im just dont have common sense when it comes to wireing... i really dont know where to hook anything up unless someone else tells me exactly where
  11. Pflumingo
    17 Jul 2002
    Yeah, They were out of a power supply from an OLD 24Vdistribution system... They will smoooooooooooooth out anything... This thing does a flatline on an oscilloscope... just try that with a switching supply from a PC.... they are 330,000pf, or 1/3 farad a piece at 85V... The only problem is if you just unplug the thing, they will still power an led for about 35 minutes...
  12. Ubermich
    Ubermich He did it!
    21 Jun 2002
    You know, colour-coding works 75% of the time :D
  13. dez
    16 Jul 2002
    sounds like a plan to me, what i know so far (i think)
    molex... red=5v, black=ground yellow=12vor7v
    lemme know if im right
  14. Ubermich
    Ubermich He did it!
    21 Jun 2002
    yellow = 12
    yellow+red = 7
    12+5=7 :)
  15. Pflumingo
    17 Jul 2002
    Almost... If you use Red for your Ground, then the Yellow is 7, but in the original configuration, yellow is 12V over black...
    Common config goes
    y b b r
    12 0 0 5
  16. dez
    16 Jul 2002
    ive got mods rigged up, but its time to learn...
    so lets say i wanted to power anything which required 5v max. just take to female molex pins and connect themt o my wire, insert into red and black in any molex... work?
  17. Pflumingo
    17 Jul 2002
    Yup.... Red =5
    -Black=0
    5Volts....
    Yellow=12
    - Red=5
    7 volts....
    Or you could power it with USB, that's 5V also
    :D
  18. dez
    16 Jul 2002
    usb, yeah, that'd be easy, mucho' easy, but i only have 2 usb ports, and there both used up.
    what about serial port?
  19. Ubermich
    Ubermich He did it!
    21 Jun 2002
  20. Pflumingo
    17 Jul 2002
    it's got 5V but not much current... You'd be lucky to light a couple LED's anyways, one of the 4 wires for USB is strictly for power to the device... And it would seem that you could use a USB hub...even an internal one would work... if you need 5 inside the case, use the molex, if it has to be external, use the usb...
