Scratch Build – In Progress Ghettoblaster 2012 by Drakmin (DIY audio)
Discussion in 'Project Logs' started by drakmin, 27 Jul 2011.
  1. drakmin
    drakmin I don't use Dremel.
    20 May 2006
    Hello all!
    Couple of days of holiday and I already got bored. What to do? A new version of ghettoblaster! My goal is to make new version 2kg lighter and couple of decibels louder than the 2010 years model.
    Goal specifications:
    -8kg weight
    -roughly 99db/W sensitivity, atleast on some frequencies ;D
    Here's the old blaster:
    This time I want a bit military styled look, so it will be edgy and boxy. To cut the weight down from 10kg I'll be using 4mm plywood for the base instead of old versions 9mm thickness. 8" drivers will be updated to 10" fullranges 97dB/W each. First sketch:
    Here's a later 3d-render which should visualize my idea of the looks better. It has 4 detachable battery modules, two on both ends. Modules will have battery voltage displays.
    BUILDING STARTS:
    4mm plywood:
    Routing driver holes:
    First parts glued:
    Bracing:
    75% of woodwork done:
    I will keep you updated of the progress, thanks for reading!
    Roboduck likes this.
  2. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    wow... i like that old school look a lot ;)
    keep it up :thumb:
  3. drakmin
    20 May 2006
    Thanks! Drivers arrived, they are 10" 97db/W 1,5kg fullranges each.
  4. stonedsurd
    11 Mar 2009
    ANOTHER ONE?!
    Subb'd
  5. drakmin
    20 May 2006
    Yes! Actually it's going to be my 5th ;D
  6. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    LOVE the first ghettorblaster, can't wait to see this one progress!
    subbed. :thumb:
  7. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    looks interesting, I'm gonna sub I think :p
  8. guus1991
    guus1991 What's a Dremel?
    13 Mar 2011
    couldm't you make a kit form out of it, i like it a lot and would like to do the same but i don't have that mutch kno-how to make something like that ;)
    looks realy good
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Sorry but the 2010 model is so awesome nothing can beat it.
  10. Evenge
    Evenge Minimodder
    16 Sep 2006
    After seeing all your blasters I'm really thinking of building one myself. Anyway, your 2010 model looks awesome and I can't wait until this is finished! :thumb:
  11. drakmin
    20 May 2006
    Sorry for the cellphone pics. Drivers in test use, total weight 5kg (drivers 1,5kg each and the wood box 2kg). I'm really satisfied with the weight at the moment.
  12. peteski
    peteski long live the pc
    8 Jun 2011
    looks good mate cant wait to see it finished
    subscribed:rock:
  13. bludragon
    bludragon italiamodding staff
    2 Oct 2011
    six great great with the wood;)
