Long ago I had a project of these in mind, it will be a mixture of a box with a WallPC, will be prepared for both. As I had a few leftover covers and also some screws and some materials from my old casemod I started making scribbles and went designing it in autocad. This project unfortunately had no sponsorship from anyone other than me. This project started on 01/25/2017, almost a year, until finally I managed to finish it and now I will present my project: Ghost Recon PS: Sorry my bad inglish.
Finishing the drilling for 4 fans of 120 mm. Testing some hardware components. Took some oxidation because it was a long time stopped
Here you can see the lid already with the side cuts made in the sander and hand folds even, with all the screws fixed and such a hole well in the middle of the cover to fix it to the wall. The cover material is 1.25 mm steel plate. The handle already has a primer paint, developed in 3/4 "steel tube with a system created to hide the fixing screws so that it is possible to mount and dismount with ease.
