Networks Gigabit Ethernet
Discussion in 'Hardware' started by seebul, 27 Jan 2011.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi there, I've got an Apple airport (gigabit ethernet) with a cable running from it into another room to a netgear gigabit switch, there are pc's connected to both ends. Now I was just wondering what realistic speeds you get from gigabit? I was transferring some films this morning and was getting about 41Mbps which doesn't seem that great for gigabit? or is it that fairly standard?
    Thanks in advance.
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Probably depends on the computers at either end - I can easily get 65MB/sec from my server (and that's before I put the RAID card in!).
  3. kenco_uk
    28 Nov 2003
    What were you transferring? Was it a few large files or many small ones? With smaller files the speed won't be sky high as there's all sorts of acknowledgement packets being transferred along with all the data. With large files you'll be limited to speed of the hard drives or their controller at each end.
  4. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    With big files from my desktop to my NAS that's about the max I get too, from my oldest hard drive. But I get MB (megabyte) not Mb (megabit).
  5. seebul
    seebul Minimodder
    9 Aug 2005
    thanks for the replies guys, the files were all films about 3 GB each and there were about ten of them. So its more the speed of your hard drives than the network then?
  6. klutch4891
    4 Feb 2008
    As far is I've been able to tell. Even when using one of my newer hard drives I get anywhere between 35-65MB/s but it still averages around 40.
