Gigabit Wan port issue
Discussion in 'Tech Support' started by muSt, 15 Sep 2008.
  1. muSt
    muSt What's a Dremel?
    15 Sep 2008
    Hi all I just registered here because I think you can help me with some problems I have with my new router. My router is the D-link DGL-4500 and I just bought it. The problem is that my wan port is like the telephone port which is smaller than the ethernet cable. This router has a gigabit wan port which is like the ethernet ( I think you know what I mean). I would like to know how can I setup my connection with the gigabit wan. Also if needed what extra do I have to buy to make my new router run nicely.
    Thanks everybody I hope for a good start. :D
  2. capnPedro
    11 Apr 2007
    Lan ports 4-1 (blue) are for computers. Plug your modem/WAN connection into the "internet" port (grey) with a cat5 cable (RJ-45 connector; telephone is RJ-11) the green port is USB.
