Gigabyte 3D Aurora + BIG GPU?
Discussion in 'Hardware' started by batsman, 30 Aug 2006.
  1. batsman
    batsman the quiet one
    14 Nov 2001
    Hi,
    been looking at getting a new case recently as my dragon (big tower) is starting to get crampt (not deep enough). At the moment to 2 best i've seen are the aurora and the Thermaltake Eureka (which is slightly too deep (650mm)).
    From the pics i've seen of the aurora it looks like it will do the job but i'm worried it will be too short, as this image
    shows the mobo being quite close to the HDD mounts, which may cause a problem with big cards like the 7900GTX / X1900XT's due to these cards needing extra power that normally comes in from the end of the card.
    Thanks.
  2. Noni
    Noni What's a Dremel?
    8 Dec 2005
    It will be fine, 1900XTs fit fine in a Antec Super Lanboy, so any other case will be no problem.
    Look at the AKASA Eclipse, aviod Thermaltake.
  3. batsman
    14 Nov 2001
    i did look at the Eclipse, it just looks too tight for me, you have to remember i'll be moving from a dragon full tower.
    I need a case that has room for atleast 5 HDD's and minimum 3 5 1/4 yeah the eclipse would take that but its going to be a mess of cables, which is my concern with the Aurora, as the PCIe power cable need to be connected and i'm not sure if its going to fit.
  4. _Robbie_
    _Robbie_ What's a Dremel?
    14 Nov 2004
    I've got the Aurora and a 1900XT and it fits fine, and while it's tight, there's no problems getting the power into the card at all.
  5. batsman
    14 Nov 2001
    thanks for the reply. i'm probably going to get this case then, i was going to wait for the Aurora 570 but with noone know when its out the 3D will be fine.
