Hardware Gigabyte GA-MA785GMT-UD2H Review
Discussion in 'Article Discussion' started by Tim S, 4 Aug 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    SFF gaming platform me thinks :)
  3. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    I agree. Would be a welcome upgrade from my gracefully aging ECS RS485M-M + 5600+ X2 + 8800GT. I NEED a quad core and DDR3!
  4. Denis_iii
    1 Jan 2007
    yea with a 4890, though I'm eagerly waiting for ATI's directx11 cards
  5. Hustler
    Hustler Minimodder
    8 Aug 2005
    Does the BIOS have to have the ECC 'Hybrid' option in order to have a stable unlocking of 4 cores?.
    My BIOS has the ACC 'AUTO' function and can unlock by 550 to 4 cores, but they are not stable under stress testing, so i have to go back to 2 cores...
    Would the 'Hybrid' mode make any difference to their stability?..
  6. Guest-16
    Guest-16 Guest
    Basically, Gigabyte is not allowed to ship the motherboard that will unlock cores out the box. It uses its dual BIOS function to hide the Hybrid BIOS in the second physical BIOS chip. The benefit of Gigabyte's Hybrid BIOS is that you can see if the cores unlock WITHOUT having to reboot, however, it does nothing more to stabilise your cores - you either have to add more voltage or buy a new CPU.
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    How do i gain access to the 2nd BIOS with the Hybrid option?.....
  8. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Why don't you include the power consumption in hibernation and standby?
  9. Guest-16
    Guest-16 Guest
    It's simply by selection the BIOS option shown: changing the value from Standard to Hybrid within the BIOS does this.
    We never do.
  10. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Nice review. Wish manufacturers would try not to put sata ports behind the second expansion slot though, i have several motherboards (both Intel and AMD) that struggle to accommodate a Sapphire dual slot 4870 card when 4 or 5 sata connectors are attached.
  11. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    Still not good enough IMO. Draws too much power, heatsink too big, gets too hot, etc.
    I cant wait for P55 that looks to me like it's going to be awesome.
  12. Guest-16
    Guest-16 Guest
    That's with a tri-core CPU mind. Drop in a 45W CPU or 45nm Phenom II dual core and that'll drop. Use a more efficient low power PSU and it'll drop. Use slower 1,066MHz 1.5V DDR3, it'll drop. Use a 2.5" SSD and it will drop. Underclock the GPU! There are lots of ways to optimise. The chipsets are made with a 55nm process - there's literally not much more you can do.
  13. fathazza
    fathazza Freed on Probation
    20 May 2002
  14. Guest-16
    Guest-16 Guest
    No it's 785G, but just with an AM2+ socket - the chipset just needs to support the faster HyperTransport 3.1 spec for the AM3+ socket.
  15. frontline
    24 Jun 2007
    At least the sata ports are in the right place on the Asus board :)
  16. Guest-16
    Guest-16 Guest
    This will be £80 at Scan soon.
    £12 more than I was quoted :(
  17. addemup2ten
    addemup2ten What's a Dremel?
    8 Jun 2009
    is it possible to use ddr2 ram with this mobo?
  18. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Yes, it uses DDR2 memory!
  19. Guest-16
    Guest-16 Guest
  20. face
    face What's a Dremel?
    26 Jan 2009
Tags: Add Tags
