Reviews Gigabyte GeForce RTX 2060 Super Gaming OC Review
Discussion in 'Article Discussion' started by bit-tech, 2 Aug 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. adidan
    25 Mar 2009
    Yes.
    Gareth Halfacree likes this.
  3. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If CardFactoryOverclock Is True
    Then IsCardOverpriced = True
    EndIf
    Unless you're hardware voltmodding then the silicon lottery is not something you even need to consider, nor any effort OEMs may or may not put into binning chips above 'stock' clocks, because 'stock' clocks have been a misnomer for years now. Effectively every Turing (or Volta or Maxwell or Pascal or any other arch that boosts up to board power limits until hitting Tmax by default) will perform effectively identically and be limited by the board BIOS power limit. Take your lowly non-factory-OC card, download literally any OC utility, and slam the power limit up the the maximum, and the card will perform as well as and factory OC card would based on the same cooler and fan curve.
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I don't entirely disagree, but in some cases you may need modified BIOSes to make this work. e.g. the MSI card we compared to is 105% limited (based on 175W at 100%) even at max, but this GB one seems closer to 240W when maxed out, and the difference shows both at stock and when max-OCed. It's unquestionably a... question... of available power, but if a card makes more power available by design to the same GPU, that seems worth exploring.
    MLyons and The_Crapman like this.
  6. edzieba
    14 Jan 2009
    IIRC from Der8auer's OC testing, you hit the non-OEM-modifiable core voltage limit before you really start bumping against any raised power targets (the stock powertarget+120% you can set any card to is more than enough). Then again, that was testing with the FE cards that are kinda-sort-factory-overclocked-ish; if an OEM wants to lock the power target modification to less than that, that's kind of a black mark on the OEM's card more than anything.
  7. Dogbert666
    17 Jan 2010
    Which is why I was so critical of MSI. The video title literally had 'Too Power-Limited' in it. It seemed so unnecessary. Plus, at the time of testing, the Nvidia reference/FE failed to apply >100% power targets despite it supposedly doing so in software
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    £430 for a 2060 Super?!
    Whaa?!
  9. The_Crapman
    5 Dec 2011
    xaser04 likes this.
  10. Gareth Halfacree
    4 Dec 2007
    Asus GeForce RTX 2060 Super Dual Evo Advanced? Super Turbo Evo? Super Dual Evo OC? Who the hell names these things, and when did they stop working for Capcom's Street Fighter division?
    jb0, The_Crapman and MLyons like this.
  11. adidan
    25 Mar 2009
    To be fair they're still better than monitor names.
  12. xaser04
    27 Jun 2008
    Dear god...
    Saying that my wife has a very similar shroud (don't know if the actual cooler part is different) on her RTX 2080. Difference being that I paid the same as at that 2060 Super costs...
  13. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    I do see the point of blowers on cards and I'm glad there is at least one option for each card. For some builds a blower cooler really is the best option.
  14. Shirty
    18 Apr 1982
    The 2070s in my folding rigs are all blowers. When cards are running 24/7 at full load, the last thing you want is excessive heat build-up!
    MLyons likes this.
  15. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    let me simplify that
    if("RTX"){overpriced = 1;}
    jb0 and perplekks45 like this.
  16. Vault-Tec
    30 Aug 2015
    Hey man, don't rag on The New Challengers.
    jb0 likes this.
  17. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    And make a hell of a lot more sense than Intel's rumoured Ice Lake line-up...
    Dogbert666 and adidan like this.
  18. adidan
    25 Mar 2009
    Dude I just looked at their upcoming mobile stuff.
    Wtf?
    So an i5 1035G7 us more powerful than an i7 1060G7 because a 5 or 8 in the name means U series but a 0 means Y. But an i7 1065G7 is better than both...
    Oh and it's either G1, G4 or G7 depending on the igp performance....
    Is that right? Jeez, way to go Intel.
    Arboreal, MLyons and Dogbert666 like this.
  19. MLyons
    3 Mar 2017
    Normally when you see a weird product name you're like ahh. Must be something internal which makes sense on their system. For this I don't see it
    adidan likes this.
  20. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Are there meant to be more charts on page 6?
    Dogbert666 likes this.
Tags: Add Tags
