News Gigabyte readies X570 motherboards and PCIe 4.0 SSDs
Discussion in 'Article Discussion' started by bit-tech, 4 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Holy cow. I feel as if I've been asleep. Some pretty good designs there - respect to those repositioned DIMM slots but OMFG SOMEONE HAS FINALLY IMPLEMENTED A 90 DEGREE ATX CONNECTOR.
    And then done away with it on the lower-end boards...
    Why isn't this standard yet?? I've been whingeing about this for years. Probably why I've got no friends...
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I think this board looks particularly excellent, of all the high-end ones I've seen.
  4. Dogbert666
    17 Jan 2010
    A Gigabyte technical PR rep mentioned that it adds cost of production and involves more PCB layering, but I haven't looked into it beyond that. Definitely a great feature though!
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Smells like a cattle barn to me. It should make precisely zero difference compared to the usual header.
  6. Dogbert666
    17 Jan 2010
    His point was more concerning how ALL the connectors down that side are right-angled, not necessarily specific to the 24-pin. Still could be smelly though!
  7. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Investigative journalism at it's finest. Did they give a number as to how much extra it costs? Surely it's something they can tank.
  8. sandys
    sandys Multimodder
    26 Mar 2006
    I guess apart from I'd imagine limited suppliers and associated cost for a non standard part in addition there might be extra support required on the board due to forces going in a non standard direction.
  9. silk186
    silk186 Derp
    1 Dec 2014
    Just as I make the move to M.2 PCIe 4.0 products start coming out.
    Dual M.2 PCIe 4.0 slots on the ITX board is nice to see.
    Hopefully, we will see boards with 3-4 M.2 slots in ITX.
    I wonder if they can do 1 4x slot and a few 2x slots that would max out current drives?
  10. Dogbert666
    17 Jan 2010
    Nope, PR wouldn't have that info, and certainly wouldn't share it on-record if they did.
  11. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Any sign of m-atx form factor boards from any of the usual suspects?
  12. MLyons
    3 Mar 2017
    I think Asus posted one but not certain.
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
  14. MLyons
    3 Mar 2017
  15. Dogbert666
    17 Jan 2010
    Yeah Asus is mini-DTX (impact) and mini-ITX only for SFF so far
  16. adidan
    25 Mar 2009
    Do you know the difference between the x570m pro4 and the pro4 R2.0?
    Been hunting around and I can't see what the R2.0 denotes.
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    x570 pro4 R2.0? Not heard of it... maybe some confusion because they've also been showing off stuff on old chipsets?
  18. adidan
    25 Mar 2009
    It was from a January ECC entry listed here
    Suggests a X570 Pro 4, X570 Pro 4 R2.0, X570M Pro4 and an X570M Pro4 R2.0
    I just have no idea what makes an R2.0 an R2.0, maybe I should just wait and see if it is a 'thing' although it looks like Asrock have use R2.0 on other boards before. I would have thought it meant revision 2.0 or something but that would make no sense with a new board :worried:
  19. RedFlames
    23 Apr 2009
    Maybe they've pre-registered the name so they can put out a rev 2 if they need to withough having to wait for whatever.
  20. Anfield
    Anfield Multimodder
    15 Jan 2010
    Could well be, maybe they'll use it in a couple month for the inevitable Zen 2 APUs to denote boards that ship with an updated bios or something like that.
Tags: Add Tags
