Hardware Gigabyte Responds to LGA1155 Socket Issues
Discussion in 'Article Discussion' started by arcticstoat, 20 Jan 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. llOriginll
    llOriginll Minimodder
    20 May 2010
    Yeah, I can actually believe that. A re-iterated problem from last generation? Incredibly unlikely, it'd be top of the list of things they'd be looking out for.
  3. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Yeah, urrmm.... because nobody would ever think of overclocking....
  4. Guest-16
    Guest-16 Guest
    Well they are testing what you actually do, and credit to Gigabyte; they realise that if you don't know the limits, you can't push them further or advise people not to do certain things.
  5. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Kind of puts this topic to bed now as I didn't even know of the problem with 1156 in the first place. Even if there was, I'm sure it would have been fixed for 1155.
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Actually it's a little bit unfair to blame Gigabyte for this kind of stuff, as they're not manufacturing the sockets themselves but Lotes or Foxconn does.
    True, Gigabyte needs to make sure that they don't use faulty sockets in their products, but these new sockets intel introduced with the Core-series (because intel wanted to shift the damaged-pin-problems to the mainboard-manufacturers!) can be damaged rather easy in comparison to the old ones which are still used by AMD.
  7. FelixTech
    FelixTech Robot
    12 Jun 2009
    I wouldn't be surprised if they do some other tests beyond overclocking (like with some sort of fake CPU setup that can draw silly amounts of power/voltage). If they are durability testing the mobo they probably wouldn't want the overclockability of the current Intel CPUs to affect whether they can test properly...
  8. B1GBUD
    29 May 2008
    Don't get me wrong, I'm not blaming Gigabyte. In fact I'm happy they're stressing these boards to the absolute limit. If it means less failures when they hit the shelves then I'm all for it. But when I read the comments, it sounded like they don't expect people like us to explore the upper limits of boards ourselves.
    We've all been there, just a bit more.... a little bit more..... another pinch..... Bang or BSOD!
  9. Azayles
    Azayles Minimodder
    6 Jan 2008
    "Our testing involves overclocking and other various tests to which no motherboard should normally be exposed"
    I so wanna be a fly on the proverbial wall during those tests!
  10. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    Bad Gigabyte! Very Bad! Not only do you lack EFI on your 1155 MOBOS but your burning stuff up and selling it. I used Giga Mobos for years but I'm off to ASUS for my 1155 upgrade.
    i do like the fact that Giga Q.A. the crap out of their products just don't sale us the toasted ones.
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    The board in question was given to a reviewer and not sold.
  12. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    I like the fact that tehy responded so quickly to the potetnial issue - seems lessons have been learned from previous socket issues.
    I am using the gigabyte rev1 x58a right now and it's awesome, on every level.
  13. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Seems to be a storm in a teacup if the problem hasn't been replicated on boards purchased at retail or other manufacturers boards.
  14. Azayles
    Azayles Minimodder
    6 Jan 2008
    Gigabyte really know how to socket to the man.
    ..I'll see myself out.
    kenco_uk likes this.
  15. kadombing
    kadombing What's a Dremel?
    24 Jan 2011
    I bought p67-ud5 last December and there was something odd regarding the packaging. The inside box that holds the motherboard is slightly ripped, and the anti static plastic is hold closed by a masking tape. Just ordered te CPU, so I haven't tested it yet.
    Hopefully it is not a reviewer's tested board or worse, a faulty board..
Tags: Add Tags
