Hardware Gigabyte Sumo 4112 Case Review
Discussion in 'Article Discussion' started by Claave, 7 Aug 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. ry@n
    ry@n Well-Known Member
    31 Aug 2005
    Looks like Gigabyte should stick to what they know best!
  3. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Looks nice, shame about the cooling tho.
  4. Paradigm Shifter
    10 May 2006
    With the CPU cooling so well catered for, it's a pity that the GPU isn't. Seems like it could do with a couple of 120mm fans on the side panel directly above the GPU area...
  5. bradders2125
    bradders2125 New Member
    14 Jul 2008
    Why did they make it so tall, look at the space above the mobo. It needs more length not height.
  6. Paradigm Shifter
    10 May 2006
    Bear in mind that it's not a typical 'modern' case - the PSU has to go in the top rather than the bottom.
    The extra space between the mobo and the PSU is probably to account for oversized heatsinks like a TRUE120.
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    funny you should say that, i have a Gigabyte Aurora 3D and have ended up modding a 120mm onto the inside of the mesh on the side panel. it works reasonably well, but the fact is that this design just doesnt have enough airflow, nor does it have the length required for a large graphics card.
    i love the way my case looks, and i bought it mainly based on that if im honest. although if i had my choice again i'd have gone for a P180/90.
  8. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    Way overpriced for waht it is,i'm surprised you gave it 5/10 for value.Better to be had for less!
  9. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    If they stick with it and try to improve where they fall short, they'll be able to create good cases eventually. Being generous, they're having teething problems. If nothing changes, their case design department is rife with incompetence.
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    I think incompetance is a little harsh. More stagnant. The Sumo we've reviewed here is, basically, a 3D Aurora with a face lift in black aluminium. The fact that Gigabyte are still using the blue 120mm fans from the aurora as exhausts, despite this case's inbuilt red lighting is dead give away.
    I do agree though, that it'd be nice to see some genuine new designs from manufactuers, instead of retreads of older models with new fascias and a few tweaks here and there, such as Antec's recent refreshes.
Tags: Add Tags
