Reviews Gigabyte TRX40 Aorus Xtreme Review
Discussion in 'Article Discussion' started by bit-tech, 27 Dec 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    I'd like to see the BOM on this thing, Just to see just how much it's a genuine step up in terms of quality of components or a cynical marketing cash grab exercise, for those who don't have to ask 'how much?'
  3. nikiti
    nikiti What's a Dremel?
    11 Oct 2019
    it's quite expensive I must say....
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you don't need 2x Intel 10 Gb Lan don't pay for it and buy a "regular" TRX40 board instead?
  5. nikiti
    11 Oct 2019
    well that's above and beyond my budget for sure....
  6. Paradigm Shifter
    10 May 2006
    It ticks just about every box I have that needs ticking. I agree with Hustler - I'd like to see a BOM for this. The 10GbE NICs aren't all that cheap, but they're not as wallet-busting as they used to be.
    When the 64-core CPU variant comes out next year, I wonder if I can convince my boss... :D
  7. sandys
    sandys Multimodder
    26 Mar 2006
    Bill of Materials, which on nearly every piece of hardware is so small.
    Guest-44638 likes this.
  8. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Is this only for having a passthrough connection off to another device, or can one board/machine utilise both inputs to be faster?
    I've looked in the past and came up with something to do with port splitting or similar, but I wasn't any clearer.
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Out of the box they are independent of each other, so you could for example run one connection to a switch and the other to a second pc.
    But since both are from Intel, there is also the option of various ways for them to work together, here is an Intel tutorial on it:
    https://www.intel.com/content/www/u...0032008/network-and-io/ethernet-products.html
  10. ModSquid
    16 Apr 2011
    Ah, nice one. Will check it out!
  11. ModSquid
    16 Apr 2011
    After reading that Intel article, I'm thinking dynamic link aggregation would be the way to increase online speed, but do many routers support that 802.3 standard? I was hoping to just shove two Ethernet cables into the router, set the team up and be done with it, but it surely can't be that simple (is it ever?)...
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    Not all that common, at least on consumer ones, gotta gate some features to justify enterprise pricing after all:p
Tags: Add Tags
