Motherboards Gigabyte with Graphics
Discussion in 'Hardware' started by chrispy61, 11 Apr 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    Which Gigabyte mobo has build in graphics, if any? Looking to use with i5 chip,
    Cheers
  2. jammy_fred
    jammy_fred Minimodder
    26 Jan 2010
    Any gigabyte motherboard using the H55 or H57 chipset will be compatible with onboard graphics for an i5 (apart from the i5 750)
    The built in graphics for i5 CPU's is actually built into the chip and not the mobo, so you just need an 1156 mobo with the outputs/right chipset.
    All of these should be compatible:
    p.s. this will only work with i5 650, 660, 661, 670 and the i3 chips.
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    http://tinyurl.com/ycv8jwg
    Sorry, Just found out about that and I couldn't help it :p :clap:
  4. chrispy61
    29 Jan 2010
    That would probly be funny if that was the question being asked (i5 Compatible Gigabyte Motherboards) I no what ones are compatible, just what ones have graphics build in.
    http://tinyurl.com/yboably
    :thumb:
  5. reggie50
    reggie50 Minimodder
    24 Apr 2009
    I'm not sure any do have gfx built into the mobo as most of the i5's and the i3 have gfx on the cpu.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Hate youu :lol:
  7. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Can i safely assume without clicking on them that thoes urls link to lmgtfy.com?:)
  8. chrispy61
    29 Jan 2010
    :D :thumb:
