News Gigabyte X38 and RD790-DQ6
Discussion in 'Article Discussion' started by Da Dego, 30 Aug 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. atanum141
    22 Jul 2004
    Holly ****
    I think the new AMD chipset will start putting the cpu wars back into motion
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    wallets at the ready.
    but more of these will help me save a few quid
    and im looking forward for Bit-tech's reviews on the x38-DQ6 and the MaximAsus.
  4. Yubalostia
    Yubalostia What's a Dremel?
    15 Feb 2007
    yeah, I like how that new AMD chipset sounds... mine should be arriving today, so... we'll see. nice article BTW
  5. Guest-23315
    Guest-23315 Guest
    Ooh! feature full!
  6. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
  7. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    since that AMD mobo has 4 pci-e slots... can u do crossfire, then have 1 or 2 other pci-e cards so u can have crossfire with multiple monitors? or... no chance in hell?
    also, can you do the thing i heard about a real long time ago? where u have crossfire and another gfx card that does physics?
  8. Mister_Tad
    27 Dec 2002
    dear lord!
    Is that 3x4, 2x6 or actually 12?
    Would like to see a bit more in the way of PCIe slots on X38 boards though, with a bit more flexibility
    Would love a board with a single x16 physical/electrical and 2 x16 physical/x8 electrical
  9. koola
    koola Minimodder
    11 Jul 2004
    Is it just me or did the AMD board get all the nice features!
  10. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
  11. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    nice features.....
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  13. zoom314
    zoom314 Minimodder
    10 Jun 2003
    Blue rules, It's a nice cool color too. :D
  14. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
  15. Redbeaver
    15 Feb 2006
    oh, btw, (how do u edit comments anyway), thx to that post i forgot what i came to say......
    where's my nforce7 or wutever?? i want SLI with Agena!!!! :D
  16. Mister_Tad
    27 Dec 2002
    you see that button at the bottom of your forum post that says "edit" :eyebrow:
  17. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    Can anyone clarify how many SATA ports the GA-X38-DQ6 has. The spec on OC's says 6 plus 4 eSATA but on the board pictured by BT, I count 6 orange SATA sockets and what looks like 2 purple sockets making 8 SATA ports; plus the 4 eSATA ?
    Or are those purple sockets something else ?
  18. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    All of this new stuff, and I just managed to get a Core2Duo and a 975X board this year. I don't really see much point in quad-crossfire as dual card setups are already really expensive and not a very economical solution. And there really aren't enough PCI-E devices that aren't video cards to use up 4 slots, unless you need multiple raid cards for something.
  19. Guest-16
    Guest-16 Guest
    There are 8 onboard but you can adapt 2/4 to make eSATA ports out of them with the included bracket in the box. That's if Gigabyte includes one or two brackets, usually there's only one for two ports.
    Those purple ports are from the ITE/Gigabyte chip that also provides the IDE. They aren't native to the southbridge.
  20. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
Tags: Add Tags
